Easy Drill Stand for Rotary Tool
Introduction: Easy Drill Stand for Rotary Tool
I needed a drill stand for Rotary Tool. I didn't  find any usable for my Rotary Tool so I decide to make my own.
Step 1:
All you need is:
- piece of plywood,
- 2 short Drawer Slide
- 1 Pipe Holder
- piece of gum
- some screws
- glue for wood
- Drill Vise
Step 2: Cut the Plywood
Cut the plywood in 4 pieces.
1 piece for a base (16,5x22,0)
2 pieces for a tower (16,5x3,5)
1 piece for drill holder (16,5x4)
Step 3: Make the Tower
Glue together the 2 pieces (16,5x3,5)  to build tower.
Drill 4 holes on one side to fasten Drawer Slides.
2 holes on top to snap the gum.
And 2 holes in bottom to fasten the tower to the base.
Than fix the tower to the base with 2 screws. Glue will make it even stronger.
Step 4: Fasten the Drawer Slides
Take the Drawer Slides and run the gum in it.
Fasten both Drawer Slides on front of the tower.
And then snap the gum on top of the tower.
The gum will help the drill to come back up.
Step 5: Fixing for the Drill Vise
Drill 2 holes to the base for fixing the Drill Vise on the base.
Step 6: Make Holder for the Drill
From the piece of plywood (16,5x4) cut 4 equal pieces.
Mark a curve for better fitting the Pipe Holder.
Than glue all pieces together to form a base for holder.
Cut the curve and fasten the Pipe Holder to it. Depend on Pipe holder, but mine has a M8 matrices, so I fixed it with one contra Screw.
Than fasten the whole holder to the Drawer Slides.
Step 7: Finalizing
I cut the base just at the end as it was more stable to work this way.
Fix the Drill Vise and put the Rotary Tool to the Holder.
You can paint it if you want.
And that's it :-)
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Is that one of the newer Dremels? Because Dremel has a drill press/ workstation combo for about $50
    Hi, no it is some no Name Drill from my father.
    Getting to this party way late, but that's a Radio Shack roto tool. I know because I have one.
    This is cool. How do you keep the position of the drawer sliders from sliding down?
    Hi, thanks :) There are this 2 pieces of gum in Step4. It has enough resistance to keep the drill up.
    Gum = elastic band? In the US "gum" usually refers to chewing gum.
