loading
I made this ferret shaped cake for my daughter who loves ferrets and all things ferret related. If you have the right tools, the cake will take less than an hour to decorate. The decorating bags are fairly inexpensive and the Grass and Hair Tip can usually be found for under $2 at most craft stores. The cake I used is a boxed mix and the icing is also store bought, though you can definitely make this using made-from-scratch cake and icing.
Materials:
  • 10 inch round cake (can also use 8 or 9 inch, but the pictures show a 10 inch cake)
  • Serrated knife - to sculpt the cake
  • Chocolate and Vanilla Icing (can be store bought)
  • Decorators Bags (2)
  • Grass and hair decorating tip (I used Wilton tip 233) - having 2 of these would be helpful because you need to switch from one icing color to the other.
  • zippered sandwich bag
  • Scissors
  • Chocolate Chips (2) for the eyes - I used standard sized chips - not the minis
  • Small cinnamon candy or small red round or heart shaped sprinkle (1) for the nose
Step 1: Carving The Cake
NOTE: If you are using a boxed cake mix, add 1/4 cup flour to the mix before baking. The additional flour makes a denser cake (easier to carve without falling apart). poured the entire mix into the 10" pan and baked it for the amount of time a 13 x 9 cake calls for. If you are making a smaller cake, use less mix and test your cake for doneness so you don't over bake it.
Once the cake has cooled, carve it as shown. The head and four legs are separate pieces. The body and tail are all one piece. The pieces don't have to be perfectly sculpted. They just define the basic ferret shape. Position your pieces on your serving plate.
Step 2: Prepping Your Icing
Prep one of your decorating bags with the decorating tip. Mix a small amount of white icing into the chocolate icing and stir until you get a marbled look. This will add a little bit of color variation to the ferret's fur.
Place the marbled icing in one of your decorating bags. Squeeze the air out and twist the top of the decorating bag.
Step 3: Icing The Body and Tail
Remove the leg pieces and set aside.
Starting at the tip of the tail, begin piping on the icing in the direction of the tail end. You want the "fur" to lay  towards the back instead of straight up. Once you cover an area that will have a leg piece against it, lightly press the leg into place in the icing and cover with icing as you did the tail and body, this time pulling the "fur" down towards the plate.
Step 4: Attaching and Icing The Head
Ice the seam between the body and the head. Press the head lightly in place. Continue with the chocolate icing all over the head leaving blank places across the top of the head and around the nose for the white icing to create the ferret's "mask".
Once the chocolate icing is completed, clean your decorating tip (but do not discard your leftover chocolate icing), place it in a new decorating bag and fill the bag with white icing. Fill in the parts of the face that need the white icing. If you are using 2 decorating bags with tips, you can alternate between your icing colors instead of completely finishing one color before starting the next.
Place a small amount of your leftover chocolate icing in a zippered sandwich bag. Squeeze out the air and close the bag. Using your scissors, snip of a tiny piece off one of the bottom corners of the bag. Twist the sandwich bag as you did the decorating bag with all of the icing pressed toward the snipped corner. Using the sandwich bag, pipe two "C's" on the top of the ferret head for ears.
Position the cinnamon candy for the nose and the chocolate chips for the eyes.
Using the edge of a knife, dab a small bit of white icing on the eyes to highlight them.
All done! Enjoy!
cute
Thank you :)
I play an online game called Second Life. Where one of my avatars is a ferret! I am so passing the link to this to all my ferret friends when I get online! Now.. to make a sock for this ferret cake.. just have to know us ferrets on SL ^^ keep up the great work!
That's so cool! I have to mention...my daughter's other favorite animal (second to the ferret) is a wolf. She perked up quite a bit when she saw that you had a ferret avatar AND your name is tattoo_wolf :)
Oooo, the first picture looks so much like a cocker spaniel. I guess the cake was dispatched in a humane way and eaten.
But of course! My daughter had to have the head to herself, though.
Great idea, very creative
Thanks so much!
This is so fun! Such a great idea! 5 stars!
Thank you!
This is a ferret cake. I can't beleive it.
It's not something you see every day, is it? :)
Not at all! For an added bonus, you could make it a carrot cake, and give the ferret a carrot, making it a Carrot Ferret Cake.
:) Now I'm wondering why I didn't think of that!
That's a brilliant idea ilpug!
Aww, thanks. :P
About This Instructable
4,702views
19favorites
License:
Bio: I love to create. Between crafting, sewing, crocheting, and cake decorating (www.creativecakemaker.com), I keep myself pretty busy :)
More by mrscoloradogal:Electric Guitar Cake Creating Silhouettes Cute Ladybug Cupcakes
Add instructable to:
