3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Firework Photography
I Know this is a bit late for fourth of July, but fireworks still go on after the fourth
In this Instructable I will show you how to take great firework shots at night, with almost any camera.
Step 1Get Your camera
Get Your camera
The camera i will be using is a Canon Rebel XTi , a SLR. Almost any camera with adjustable settings, can be used in this instructable. Almost any Canon Camera has settings like the rebel xti, so you should be able to follow along. I am certain that fuji and a few other brands have these manual settings. Other brands may work, but you will have to consult your manual for those.
12 comments
Jul 4, 2011. 7:12 AMSmoke_me_a_kipper says:
If you have a Canon P&S camera give CHDK Canon Hack Development Kit a try. One of the features is the ability to use scripts and save files as RAW. By using a Motion detection script I just point the camera at the sky, press the shutter to activate and sit down.
https://picasaweb.google.com/graeme.ellis/CanadaDay2011?authuser=0&feat=directlink
https://picasaweb.google.com/graeme.ellis/CANADADAYFIREWORKS2009?authuser=0&feat=directlink
Jul 3, 2011. 3:59 PMNatcan says:
I have fun taking pictures of fireworks. I forgot my tripod so I got some interesting shots, some are hard to tell that they are fireworks.
Jul 3, 2011. 8:57 AMesiegel1 says:
shutter speed is less critical than f/stop for capturing fireworks. calibrate the aperture, then use bulb to mess with how the exposure changes the 'streaks'
Jul 3, 2011. 8:55 AMesiegel1 says:
From CreativeLIVE's free fireworks photography class:
If your camera happens to have a "bulb" setting, use 'bulb' to control how long the shutter stays open. longer exposures will result in streaks, shorter ones in sharp bits of the firework. Depends on the picture you're going for.
Recommended with an aperture of f/11 to f/16. Fireworks are BRIGHT!
Apr 19, 2010. 7:15 AMFrancois94 says:
I have read somewhere (probably www.kenrockwell.com ) that you should use either Image Stabilisation OR a tripod, but not both (i.e. turn off Image Stabilisation when using the tripod).
Jul 3, 2011. 8:30 AMTongblack says:
You are correct. When you have image stabilization on it tries to guess which movements are not ones you as the photographer intentionally make. When you have it on a tripod, there aren't really going to be any movements for it to correct, and sometimes it tries to correct movements you INTEND to make, so you end up with a jumpy picture. Now, this probably won't affect taking stills very much, but is definitely an issue when you're taking video.
Jun 13, 2010. 2:24 PMwobbler says:
I suspect the OR means for night shots, use either image stabilisation or a tripod at least. I can't see why image stabilisation needs to be off on a tripod except that it's not strictly necessary. Having both on however shouldn't be a problem because the image stabilisation compensates for the camera moving so on a rock solid tripod it may simply have nothing to do. The other trick for night time shots is to use delayed shutter mode so the camera settles before taking the shot from a tripod, but with fireworks etc. that's not always possible. This can also work when hand-holding the camera because you are more still (stiller?) if all you are doing is holding the camera and not also pressing the shutter. Have fun with your camera though!
Jun 13, 2010. 3:49 PMFrancois94 says:
"Believe Nikon when they say don't use VR on a tripod. It screws up the image by adding blur! Likewise, if you brace the camera against something also turn the VR off."----- Source: http://www.kenrockwell.com/nikon/80400vr.htm
May 14, 2010. 12:14 AMDuchateau says:
Good writeup, Heinecke has the right idea with ISO 100 or lower, fireworks are amazingly bright as far as camera sensors go, i took these a couple years ago, very first time i've ever shot fireworks, you just have to get out there and do it, a tripod is a must!
Sep 15, 2009. 8:31 AMHeinecke says:
You should use the manual mode. F around 8-11 or even higher if the pictures are still overexposed. Furthermore you should use the bulb mode. Press the button when you hear/see the firework and hold it for about 1-4 sec. ISO 100 or 50. Don't forget your tripod.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:jssteinke
