Introduction: Easy Fix for Falling Fly
About: Made in Canada, I grew up crafting, making, and baking. Out of this love for designing and creating, I pursued a degree in product design from Parsons School of Design in NYC. Since then I've done work for Mar…
This is one of the easiest and cheapest solutions I've ever heard for a problem that can potentially cost you a lot of embarrassment and social awkwardness. For 10 cents you can ensure that your fly is never down in public again!
Step 1: Supplies
  • one 3/4" OD double key ring (just larger than the button on your pants)
  • really strong nails or a small screwdriver
  • pair of pants with a constantly low flying zipper
Step 2: The Quick How To
Use your nail or screwdriver to open up one end of the key ring and insert the end into the top hole of your zipper pull. Turn the ring until it is all the way on the pull.
Now you can use the ring as both a bigger, and therefore easier, pull tab AND a locking device. To lock your zipper securely 'up', pull the zipper all the way closed and slip the ring over the button. Put the button through the button hole as you normally would and....Voila
Step 3: Seamlessly Secure!
Voila! It's completely unnoticeable and completely secure! Now go forth into the world with confidence that your barn door will remain closed until you see fit to open it.
Step 4: Animated Actions!
Full Spectrum Laser Contest
