It can be made with not much more than than an Oxy-acetylene torch, hacksaw, and drill press. The materials are probably all available at your local Big Box hardware store, though you should see if you could buy the angle iron as cutoff remnants from your local steel supplier, as it will be a lot cheaper.
Remove these ads by
Signing UpStep 1Materials and tools
Angle iron, approximately 2' x 2', 2 pieces 12-18" long
Angle iron, 3/4" x 3/4", about 2'
Steel flat stock, 1" x 1/8" thick, about a foot should be plenty
2" clevis pin and a cotter pin or clip
3/8 bolt, 1 1/2" long should do, or Metric 8, or whatever you find in your junk box around this size.
A nut to match your bolt if you don't have the right tap size
And the following tools:
Drill press and drill bits
Tap to match the threads on your bolt (optional)
Hacksaw
Vise
Oxy-acetylene torch, and welding or brazing rod
well illustrated
love it,
gonna make one.
need to get one of those special flames and retain my finger tips for a little more time.
cheers.
I get the issue about bending the fork Blade.
But I cannot understand, How can you reduce the tube diameter at the end of the tube???????.
Thanks
Its tappered tube, the only thing that you do it bend it.
I Say that, cuz I'm working on a personal project "Penny farthing".
The Fork Blade of a Penny farthing doesnt have the rake like a normal bike.
But It also have tappered end at the end of the Tube.
Then, I'll buy square tube for the beginning of tube and weld a tappered tube at the end.
Thanks man!!!!
