Step 4The Clamp
iImage Information
The clamp is made from a couple of piece of the bar stock. Depending on how thick and tall your angle iron is you'll have to modify the dimensions of this part. But basically you weld the four pieces together - two legs and the top part which is two pieces doubled up. After it cools, you can round off the bottom part on a grinder and drill it for the clevis pin. Then drill and tap the top for the clamping bolt. If you don't have the right tap size, just weld or braze a nut on top instead
