3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Fork Blade Benders
Step 6Assemble and bend away
Thread in your bolt, attach the clamp with the clevis pin, and you're ready to go.
Clamp the far end of the bender to your workbench. Clamp the tip of the fork blade with the bolt, and bend the leg down. You will probably need to slide a piece of larger tubing over the fork blade to get enough leverage. Some designs use two long arms mounted to the frame with a grooved nylon roller to lever down on the fork leg, which would be an easy thing to add to the frame.
If you are trying to do tight bends, large rakes, and are using thin fork legs, you might have to pack the legs with sand to keep them from kinking. The one in the photo below has a pretty tight radius, I'd recommend you try something a little flatter to start out with.
2 comments
Feb 5, 2009. 11:01 AMdniedz says:
does the bolt seat into the actual dropout, or the base of the fork leg? what would you say the total cost of this was?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:drwelby
I grew up on Legos and the Whole Earth Catalog. These days: bike builder, map maker, trail sleuth.
