3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Fruit Fly Trap
Easy Fruit Fly Trap
I used to make the inverted cone type traps but one day I didn't have any tape so I tried this. Much to my surprise it worked just as well, but was way easier to make.
Fruit flies can be a pain in the kitchen, but with a good trap it's surprising how quickly you can get rid of them.
The steps are:
1. Put bait in the bottom of the container
2. Cover top with plastic wrap
3. Secure with rubber band
4. Poke holes so flies can get in
Step 1Materials
Materials
Materials:
1. A container
2. Plastic wrap
3. Rubber band
4. Bait
Tools:
1. Something pointy
34 comments
Oct 20, 2011. 6:45 AMsmf257 says:
@NoFiller
I really appreciate your help. We retooled our trap a bit and have really de-bugged the office! The cup of Apple Cider Vinegar with a small bit of banana left to ferment over night proved to be irrisistable to the flys. Also we cleaned out the small garbage can that was a breading ground due to one of our office mates (Jeff) constantly tossing fruit peels and cores in there.
Another colleague (Dan) found great success using a bit of red wine and banana at his home. After leaving it to germinate for a few days he was slaying fruit flys left and right!
thanks so much for the help!
happing hunting to all!
Jan 31, 2012. 2:55 PMmainah says:
Tell, Jeff, to take his scraps home and compost them or you'll toss him in the dustbin. ;-)
Nov 2, 2011. 2:32 AMsquirrellover21 says:
I use a large martini glass(the more flat area to allow the flies, in the better), cover with plastic wrap with dime sized holes in it(the flies will not be able to crawl from glass to plastic wrap for some reason), and use about a half ounce of sweet vermouth in the bottom. It's like a drunken fruit fly orgy in there.
Oct 5, 2011. 7:38 AMsmf257 says:
Used lemon-lime gatorade and some banana
25 minutes in and still no flys in the trap!
HELP! our office is infested!
Aug 19, 2010. 11:22 AMWolfbird says:
You can also cut the top off a 2 litre soda bottle and reverse the top to make the funnel. No tape required, it makes a pretty good seal on its own. I've been resuing the same one for a few days, I just bring it outside and knock out the contents.
Jul 22, 2010. 5:32 PMNapole says:
Neither vinegar nor coca cola attracted any flies into the home made fly trap :-( but whatever the commercially sold fly trap used as baits has been working like a charm. The first hour there were at least 20 flies dead and no more lit' buggers buzzing in our kitchen. Now we need DIY moth traps.
Jun 28, 2010. 4:21 PMrainbowlory says:
i live in the wine country in California and when they start to lay out the grape skins back in the fields it stinks so bad and then we are so at the mercy of fruit flys...... i'm so excited about this.. thanks
Oct 23, 2009. 11:12 AMricharpo says:
You could take the cling film off, and put it outside to let them escape.
Oct 23, 2009. 6:54 PMcrickle321 says:
What would the benefit be of letting them escape outside?
Jun 3, 2010. 10:51 AMtgosser137 says:
To provide food for other insects/birds etc. that eat bugs... yum!
Dec 27, 2009. 7:42 AMaccordavillain says:
I've done this trick with very good success. I used red wine as bait one year but it wouldn't attract the next, must have killed off the alcoholics. so I switch up my bait
Oct 24, 2009. 11:26 AManotherbob says:
 I thought I invented this! LOL
I use a mix of wine or beer and vinegar with a piece of what ever they were hanging around in the middle.
The vinegar will dissolve the little buggers and you won't even notice how many you have floating around in there.
Oct 28, 2009. 10:54 AMLancePenney says:
I usually get a big fruit fly problem while I'm brewing beer in the kitchen during the summer. I always lay a tissue over the airlock to stop them from getting into the fermentor but this looks like a better solution.
Thanks a lot!
Nov 1, 2009. 12:07 PMhbk2flyer says:
 I like to use a bit of red wine, then let them go outside to feed the spiders!
Oct 28, 2009. 1:05 PMmikaelthemycologist says:
You should also pour boiling water down the kitchen sink drain. The flies like to breed in there.
Oct 27, 2009. 10:30 AMTofu says:
I tried the cone/funnel form factor traps and they didn't work for me.  However this ible's form of trap worked like a charm for me!
I did change the manufacturing method a bit though.  I stretched the plastic wrap across the container and then used a heated paperclip to melt holes in the cover.  This allowed me greater control over the size, and placement, of the holes.
Filled with cider vinegar to a depth of about 1/4" and added a drop of dishwashing liquid.
The morning after the first night of placement  there were at least 30 flies drowned in the vinegar.  Swapped out the vinegar and the next day another 30 flies.  I'll have to snap a pic of the results.  IT'S AWESOMELY EFFECTIVE!
Oct 24, 2009. 10:11 PMWickedFabala says:
watermelon always bring em in!
Oct 22, 2009. 4:12 PMSirBrittanicvs says:
Some Balsamic vinegar also works too, probably the same for every other vinegar.
Oct 22, 2009. 3:29 PMkissiltur says:
We've been using these for a few days, and they are great. Far fewer flies annoying us, and vastly more successful than the tape traps we were using before. We have red wine vinegar and a drop of soap in them.
Oct 22, 2009. 11:07 AMcofosho says:
I lived in a co-op (with compost and lots of fresh fruit on the counter) for a year and was always thwarted by a lack of tape. Our lifestyle also meant very few disposable bottles came through (except beer). I never thought of the plastic wrap and rubber band. GREAT idea.
Oct 22, 2009. 7:03 AMendolith says:
Why cut off the top?
Oct 16, 2009. 5:57 PMEaglesNest says:
Great idea! I've been using the cone trap too, but I'll have to try this one. I found the best bait was apple cider vinegar with a drop of Dawn soap. They'll go for that over any over ripe fruit on the counter every time.
Oct 19, 2009. 8:27 AMRetroTechno says:
I also tried the apple cider vinegar and soap as bait.  It works very well, and you don't have to worry about it going bad.  The soap is essential to break the surface tension so the little buggers will drown.
Oct 17, 2009. 7:25 PMatombomb1945 says:
Had an incident this summer with some "old" bananas that had attracted a colony of gnats.  I used the apple cider trick and they were all gone within a week.  That stuff will attract just about any fruit eating insect.
Oct 19, 2009. 5:42 PMdigitalbrad says:
I use a saucer or a small plate.  About 5" across.  You can then stretch the plastic wrap across it and it will grip and you don't need the rubber band. The fruit flies like to wonder around the edges and don't like climbing on the plastic wrap to much.  Balsamic vinegar works well on attracting them also.
Oct 18, 2009. 10:51 AMKirbsome! says:
I have an idea:
Insert a 1" piece of straw trough the hole, so its almost completely inside the container. That way the flies will get in, but not out.
Great 'Ible!   :D
Oct 16, 2009. 5:26 PMcaledonian says:
A drop of dish soap helps break the water tension so that they are more likely to drown.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:NoFiller
