3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Fruit Zest - Part II
video Easy Fruit Zest - Part II
A unique and easy way to make fruit zest using only a knife and a spoon without fear of getting unwanted bitter white pulp. Fruit zest such as lemon, orange and lime can open up an entirely new dimension to even the beginning cook from garnishes to highlight flavors that will astonish even the most sophisticated palate.
I keep lemon, lime, grapefruit and orange zest in the cupboard just in case I want a handy garnish, to flavor tea or coffee and a variety of other novelty uses. For example boil some water on the stove and drop in some zest for a refreshing scent throughout your home.
Okay then let's get started, here's what you will need:
Obviously you're going to need one or more lemons. Wash the outside thoroughly. Once you see how easy this is you may very well find yourself using it enough to want to dry it and store it so it's always available.
A sharp knife for cutting the lemon
A spoon
If you're going to make a lot and store it you'll need a container of some sort and a cookie sheet to dry your zest on (for longer term storage).
Okay then let's do it...
Making Fresh Zest
Using the knife cut the lemon into quarters. Use your thumb to peel the rind off in a single piece.
Don't worry about the pulp, worry about getting the rind quarter off intact.
Once you have peeled the fruit use the edge of the spoon to scrape off the white pulp from the rind. The pulp will scrape cleanly leaving only the skin of the fruit which contains the oils that give it its flavor and scent. The lemon "nipple" is a pain and may be trimmed to make the cleaning easy.
The rind is much tougher and a different color than the pulp so its very, very, very easy to know when you're done.
I also found that if I ran some water over the pulp first most of came off quite cleanly leaving only a thin layer to be scraped off.
With your finger tips tucked back using the knuckles of one hand to guide the knife blade as you cut the now clean peel into thin strips.
Depending on your uses these strips can be cut in half or quarters lengthwise or even diced into small bits for easy mixing into recipes.
DRYING AND STORING
If you're want to dry and store the zest for future use heat your oven to approximately 200 degrees. Spread the zest strips ( or diced zest or a mixture of both ) out on a cookie sheet. Place in the oven, every 10 minutes or so use a spatula to make sure the zest is drying evenly (and doesn't burn). When its dry place it in a spice container and label for easy identification.
3 comments
Feb 1, 2010. 11:32 AMpvdl says:
That is "teh Awesome".  Particularly like the creative choice of sound track to go with the great cuisine advice.   Looks simpler than getting a dedicated zester tool.  Thanks G.
P.
Jan 27, 2010. 5:40 AMiPodGuy says:
Do you have to use the oven to dry the zest?  Can't you just leave it out on the counter for a few days or something?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
155
Author:egbertfitzwilly(More about me at LinkedIn....)
