loading
If your headphones don't work and you know its not near the jack, the fix is easy... no more than 10 minutes if you know what you're doing. Mine took a little longer since I was working on my friend's headphones at the time and they are fairly complicated. The headphones used in this instructable are cheap pieces of junk that don't work anyways but it is the same procedure that I used on my friend's.
This should work but there are no guarantees. Doing any repairs like this may void any warranty you may have. Soldering irons and other tools can be dangerous and should be used with safety in mind. I am not liable for any damage done.
Here's a fairly well-written 'ible on the wire splicing
Step 1: What You'll Need
-Wire Stripper (or similar device...knife, nail clippers etc.)
-Soldering iron and solder
-Shrink tubing (Finally found some in my house)
-Sandpaper (grit doesnt matter too much, probably something higher than ~140 should be good)
Step 2: Strip the wire
If the wire is a double, you need to pull them apart. You should pull at least 1/4" to 1/2", depending on how much you trust your soldering skills. Use a wire stripper (exact-o knife or fingernail clippers will work--be carefuler with these though) and strip the insulated wires. Separate all wires by colors (On these the colors are red, green, and copper. Generally, the colored wires transmit sound, and the (apparantly) uninsulated wire is the ground.
Step 3: Slip on Shrink Tubing
or whatever its called
Just slide it on before you twist any wires together.
Step 4: Sand the wires down.
The colors on the wires are really a thin insulating coating that needs to be removed before soldering. To do this, simply use some sandpaper and sand away until you see the copper wire. Do this with all wires, including the ground.
btw my camera really doesn't like the close-ups
Step 5: Twist and Solder
Twist all like wires together. I like to keep the grounds separate, but that is just personal preference. Once they are twisted together, put a thin coat of solder on the wire.
Step 6: Cover Solderings with Electrical Tape
This step keeps the wires from touching eachother or the ground, to make it not short-circuit.
Simply cut a small piece of electrical tape and wrap it around each wire. Cut/Fold away the excess.
Step 7: SHRINK WRAP!!!
Now slide the shrink tubing(?) back over the electrical-tape-covered wires and heat up with a match/soldering iron/heat source until you get it nice and conformed.
ZE END!!
<p>my headphones have a blue wire sticking out near the plug. What do I do?</p>
<p>can somebody help me with this please?<br><br>email me :') </p><p>-ampuanaomi@gmail.com</p>
<p>Hi.. Did you connect the wires simply by tapping them together? Audio wires are sensitive, they require constant value of resistance, so this method usually won't make it work. Try soldering them together. If you can't do that, twist them together as tightly as you can before applying the tape. If connections are correct and secure, yet it still won't work, the problem might lies in the circuit's components. </p>
actually it's like that when i bought of but they decided to refund back my money instead of shipping another. so i'm left with quite a bummer. if only there is some sort of guide/diagram to this kind/type of settings headset, checked all sorts of guide to no avail...
<p>Many thanks to the author! Those who have difficulties feel free to comment me, I'll try to help. </p>
Please help my headphones are damaged from the end of the microphone
<p>have you identified the location of the bad connection? </p>
<p>is there any significance to the individual fibers for each of the 3 wires inside? or can I just take each wire and fuse it to the new one of the apt color?</p>
<p>hey mate.. any luck repairing your headphone? the individual fiber has no significance.. A bunch of them represent the same connection, which is ground. But different bunch connects to different direction, so the significance is in each group of them, not individually. I fixed mine leaving some fibers broken, and the result is less quality for the sound. I fixed that by adding an external connection to ground. </p>
<p>I soak the plug and wire insulation I want to remove in acetone for a half hour or hour and find the insulation just peels off. If it doesn't, such as the thicker parts around the plug, soak a little more. It doesn't affect the wire lacquer, which may be good or bad, since it would be nice if it cleaned off that insulation, too. Some heat-shrink tubing slipped over the wire beforehand can be slipped over the worked area and shrunk with a cigarette lighter to add some protection/strength to the area and make it look more professional, but it will also make that section less flexible.</p>
<p>Great It really works</p>
<p>THX IM SURE THIS WILL WORK! :-)</p>
<p>Thank you for your tut. I like the part twist wires together :). </p>
<p>Awesome. It worked. Thank you.</p>
<p>Thank you very much! I made it but instead of using sandpaper i only burned the insulating coating. But your instructions very clear!</p>
<p>I am planning to do this repair, I know is the wire that connects one speaker to the other, what I don't know is what gauge of wire do I have to buy and where? Radio Shack does not have it. Inside of the cable there are 2 wires.</p>
<p>Thx for the tutorial, i made it :)</p>
<p>This didn't work on my low end Sony headphones. There is continuity but no sound so not sure what the problem is.</p>
<p>Yes I made it Nicely...Thanks</p>
<p>Please check out fixthebeat.com for any replacement parts or repair services. They work great! </p>
A nice tutorial but the finished product looks a bit chunky though.
Hi, recently my Turtle Beach PLa headset has broken, I am not sure how to fix what would you suggest? Thanks, and please answer! 2 wires are fine and I can still hear but I can't speak into it.
these are my Xtreme Xplosives 50 mm. driver over ear headphones and they cost me 45 dollars i really dont want to just throw them in the trash so any help how to wire these would be appreciated
Can't tell from that picture, but that is right at the place where it splits to go to each ear, right? <br>If so, there's two possibilities: <br>1) The wire on the right has two insulated wires and a bunch of what appear to be uninsulated strands. <br>2) The wire on the right has a bunch of what appear to be uninsulated strands. <br> <br>If it is 1), you can strip back the outer insulation a bit, and then proceed with above guide. <br> <br>If it is 2), you are best off just getting new headphone wire and soldering directly to the driver, or just getting new headphones.
Put your camera on a macro setting whilst doing close ups <br>
I took those pics a LONG time ago with a camera that didn't even have a macro function (or at least I don't think it did.&nbsp; That camera is long gone so I can't say for sure one way or another).&nbsp; If I ever get around to doing this fix again, I'll probably re-upload some better pictures.
THANK YOU MAN!!!!!!!!! You saved my headset. Funny thing was, I just burned the wires wiped it off and connected them together and VOILA!!!!. Thanks so much. I really needed them too. The school I go to uses them to interact with students. Didn't have the time nor the patience nor the cash to order/wait for a new one. So again, THANKS. <br> <br> <br> <br>A Pleased and Satisfied Student.
I signed up just to comment and say THANK YOU! You really saved my bacon with this, because at the moment I'm short on cash AND transportation, so being able to fix what I have means a lot. I actually did not have a soldering gun or even solder, but using your directions and taping it all up with electrical tape (with a bent paper clip thrown in for stability) worked like a charm. I actually didn't think it was going to, but I had nothing to lose so I gave it a shot anyway, and was absolutely amazed when I plugged it in and they worked like new! I don't really expect it to last forever, but hey, I'm not having to replace them *today*, and that's good enough! <br> <br>I honestly think what made the difference were your instructions plus all the comments that made it clear you have to sand/burn away the coating on the inner wires. It seemed like such a big deal that I did both: I burned away the coating and then sanded the fine wires for good measure, twisted them together, and there it was: good, steady sound out of both sides. I taped all the twists in such a way as to keep them permanently separated from one another, and then bundled the whole thing in tight swathes of electrical tape. Ugly, but who cares? I'm absolutely thrilled!! <br> <br>Thanks again!!!
it helps!!<br>thanks so much!
Thanks for the great tutorial. (BTW it is heat shrink tubing) :)
Thank you so much for posting these instructions. My Bose headphones were cutting out all the time and I ascertained that the wires going into the plug were broken and making intermittent contact. I tried cutting the plug off some junk earplugs and splicing them on but it didn't work (of course.) I put the headphones in a drawer and considered them junk with a vague hope that somewhere I would find an answer. Then, weeks later, I stumbled on this and learned that you need to burn off the enamel coating. I never would have guessed that. So today I went to Radio Shack and bought a $10.00 soldering iron and used a cigarette lighter to burn off the enamel and voila! my headphones are working as good as new. Thanks again.
buy the repairing parts from lunashops. it will be easy, i got my cable from them,
I have never heard of using sandpaper to get rid of insulation. I usaly use a lighter.
the tip with matchboxes was perfect.thnx:)
I stripped the wires and twisted them tried them but they don't work, still. These are my husbands headphones that he'd only had for a short time. I have a solder gun but I didn't want to solder them until I was sure they would work right.
Most of the time twisting won't work even when you sand the wires down. Even with sanding, there is still enamel left on the wire that will get in the way of the current when the wires are just twisted. The best way is just to solder the wires. To get the best connection, the cut ends should probably end up in the solder, since these won't have any enamel on them. A way that you might be able to see if the headphones to work is to try to touch the broken ends together. Good luck
use a lighter and burn the enamel off of the wire sanding the wires really does suck lol
Great advise with the lighter, now it works! tnx man.
thanks for enlighting the tutorial....
or otherwise if you don't want to use soldering machine try with lighter , there can come some smell but it isn't nothing , i don't recommend SAND PAPER , that will damage the cables..
er.. what I said up there :P
Ah it worked. Is there a way I can melt or &quot;solder&quot; the wires together using home appliances like matches e.t.c
<a href="http://www.instructables.com/id/How-to-solder/step7/Soldering-with-a-lighter/">http://www.instructables.com/id/How-to-solder/step7/Soldering-with-a-lighter/</a><br>
thanks
The wire in my earphones broke right next to the jack plug making it impossible to get any wire out of that end of the cable so I couldn't reconnect them. I had a pair of crappy headphones that I have cut up as a replacement jack plug but no matter what I do I cant get any response. Is it because headphone wires are not compatible with earphone wires?
About This Instructable
1,019,224views
58favorites
License:
More by killersquirel11:Arreglo fácil para auriculares con cables rotos PCB Creation with Eagle for Beginners Part Selection Guide for Building a New Computer
Add instructable to:
