3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Hidden Camera on the cheap (Lighter mod)!!! Big Boyz Toys
  • last photo ←
Mini DVR Modification (Lighter)  Hidden Camera
Hello today I am going to teach you how to modify the Lighter-Spy-DVR-Mini-DV Camcorder
Http://cgi.ebay.co.uk/New-Lighter-Spy-DVR-Mini-DV-Camcorder-USB-Hidden-Camera-/230632642485?pt=UK_CCTV&hash=item35b2c6d7b5
You will need:
Knife
General Tool box (Tools)
Tape
Blending Device – In this case we will be using a Photo
First you will need to remove your micro sd card from the cam and make sure it is turned off. Now carefully Using the pliers and a little help with a knife might be needed.
Now after you have dissembled the Dvr Mark up the hole on the Picture, Poster, Etc possibility's are endless with the item you are using
Make the hole where the mini cam will go and tape it down be sure to take note of the Power button though If i had a soldering iron i would solder a extra button on you can see in the picture the two holes
Step 1Securing
Securing
  • last photo ←
Now tape
1 comment
Nov 3, 2011. 10:47 AMjakovn says:
This is great! Please post bigger pictures of disassembled lighter! Do you think you could replace lenses with wide angle? Do you think you could wire larger battery? What is the voltage?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rrichards
