Step 2Assembly & Wiring
Download the ".pdf" assembly guide below and follow the steps. (04-(SESW)-Assembly Guide.pdf)
A Few Notes:
- A small 3mm hole must be drilled in the servo horn before step 3
- In Step 4 when attaching the servo horn first rotate the servo as far clockwise (looking at the top) as it will let you go. Then attach the servo horn in it's full upright position.
- Wiring is super simple. The servo plug has three pins which should be connected as follows
Pin 1 - black or brown - gnd Pin 2 - red - power Pin 3 - white or orange - signalPin 1 - attach to the negative side of your power supply (-)
Pin 2 - attach to positive power (4.8v - 6v)
Pin 3 - attach to pin 9 or 10 of your Arduino (or provide with a pulse between 1000 and 2000 mS for more details on controlling servos try (here)
04-(SESW)-Assembly Guide.pdf(612x792) 585 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
