Easy Homemade Rocket from CPVC pipe.
If you are like me, you like experimenting with designs without spending a lot of money in case it goes miserably, and you like to do things without safety taking too high a priority and obstructing or ruining a good chance to experiment. If you are not like me, it is probably for the better as you will probably live longer, but you will miss out on all the fun. In this Instructable, I will tell you how to make a inexpensive rocket out of CPVC pipe. This method of making a rocket may very well be common knowledge. Though I thought of the Idea on my own, others had thought about it as well. You could probably just do a Google search and find this-you don't need to tell me. In fact, I searched this out and I read of how someone else did this, so I felt more comfortable attempting it. Advise is most welcome. This is my first Instructable, so sorry if it is confusing. Sorry that I don't have any videos or that many pictures at the moment. Enjoy.
One more request. Please stop referring me to Google.com. I get the idea.
NEITHER I NOR INSTRUCTABLES.COM ARE RESPONSIBLE FOR WHAT YOU DO WITH THIS INFORMATION OR LIABLE FOR ANY DAMAGES CAUSED. BE CAREFUL.
Step 1Things needed
Materials
7" of 3/4" CPVC pipe.(I am not exactly sure what that is, but I found it at Ace hardware. You might find a lighter type of pipe, but make sure that the rocket engine fits snugly inside the pipe.) You will have to get it in one foot length's, so it is up to you if you want a longer rocket.
A 1" rubber stopper for the cone. (if you can think of something else, it is up to you.) You can also get this from Ace.
A sheet of balsa wood about 6" by 5" (I used a different type of light wood, But I am clueless as to what it is called.)
A normal plastic bag (for the parachute)
Thin Super Glue
Tough string for parachute ( You might could use fishing wire for this- I used what I had on hand)
Metal eye.
Thin rubber band (shock cord)
Drinking straw
Model Rocket engine. (I would use a C6-2, a C6-3, or C6-4)
Tools needed:
Protractor (would immensely help)
Hacksaw
Razor (or sharp knife)
Scissors (both light and heavier duty)
Marker
Screwdriver
Ear swab
Hot glue gun (with glue of course)
File (moderately large, but not a rasp)
Optional Paint.
20 comments
Dec 17, 2010. 5:08 PMmbainrot says:
from my experience you will want to re-enforce the balsa with glue (kinda like fiberglassing) and insure that the grain is at a 90 degree angle to the rocket. If you have the grain parallel to the rocket it will split and fall off during flight, sending the rocket in a uncontrolled spiral with no predictability.
Jan 1, 2010. 3:03 PMlessgravity says:
 Paper/ Cardstock is a better material for rockets. PVC is a dangerous material to use. PVC during motor CATOs will shatter and act as shrapnel.Even a small model rocket motor like an C, D, or E can be quite explosive if they CATO. I've seen them do this. Please be careful and use lighter less dangerous materials.
Feb 8, 2009. 12:57 AMTombini says:
Nice design Kiddo, Its good to see people building their own rockets 4/5 just for the fin design Most of mine fail due to me using homemade (and often too powerful) rocket motors
Feb 27, 2009. 3:38 AMTombini says:
no worries, for this specific rocket design what has been the best size rocket motor? C class?
Feb 16, 2009. 12:31 AMWyle_E says:
For what it's worth: CPVC is crosslinked polyvinyl chloride. It's used in household plumbing because it can withstand typical domestic hot-water temperatures, where plain PVC begins to soften. I've made model rocket tubes out of paper, laid up with diluted Elmer's glue. More tedious than plastic pipe, but definitely cheaper.
Jul 21, 2008. 11:15 PMDipankar says:
The model is very well done but , where is the engine for the rocket? What is this (C6-2,3,or 4 model rocket engine) explain yourself.
Jul 22, 2008. 6:47 PMDipankar says:
Crystal clear. Now I can use a firecracker rocket and inside the tube and make it work. This is easy and cheap. Thanks---
Jul 21, 2008. 3:09 PMmikeasaurus says:
Video of ignition! Video of crash landing! Video of burning debris!
Jul 22, 2008. 8:37 AMmikeasaurus says:
I can't think of anything off hand that would outright ignite it, but tires burn and they are rubber, and everyone knows wood already burns, seems to me like you just need to have some kind of amazing accelerant in there to really kick things off like coating the fusalage in polyurethane .. or maybe just guide the rocket into an acetone factory!
Jul 21, 2008. 11:23 AMWolf Seril says:
-1 for saying "this is my first instructable, so..."
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ClCrow
