3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Homemade Rocket from CPVC pipe.
Step 2Making the Parachute
First we will make the parachute for our recovery system. You will need this to be at least a foot in diameter. This step is somewhat self explanatory. A moderately good size of a plastic shopping bag will serve this purpose well. Trace a marker around to make a circle, and then cut this out carefully. Next. you will need to tie four 14" strings (or wires) to the parachute at quarter sectors. Now, carefully tie the other ends into one big knot. You will want to test this parachute to make sure of accuracy in it's vertical float to the ground, minimal spinning, and rigidness. Inspect the sectors where the wire is tied to the parachute to make sure it is still securely tied. When the parachute has met your standards, secure the sectors by covering it in super glue. This is an outstanding help to the parachute. If you want, you may use more strands for a better parachute, but it will make it a lot more complicated.
2 comments
Feb 16, 2009. 12:31 AMWyle_E says:
For what it's worth: CPVC is crosslinked polyvinyl chloride. It's used in household plumbing because it can withstand typical domestic hot-water temperatures, where plain PVC begins to soften. I've made model rocket tubes out of paper, laid up with diluted Elmer's glue. More tedious than plastic pipe, but definitely cheaper.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ClCrow
