3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Homemade Rocket from CPVC pipe.
Step 3Making the fins
Making the fins
Now it is time for the piece of balsa wood (or other light wood). I have uploaded a document with the dimensions if you want to trace it. You can design your own if you want. Cut three of these out carefully with a razor or sharp knife. Sand the edges of each fin smooth except for the 2 1/2 " edge that attaches to the rocket. You will need this edge to be flat, level, and having as much surface as possible. Preferably, the balsa (or other wood) should be at least 1/8 " thick (It depends on the strength of the wood you are using). I don't have any experience in balsa wood as it is rare in my area, so pardon any ignorance I might express. Because the rocket is heavy, thin balsa wood is very likely to break.
2 comments
Dec 17, 2010. 5:08 PMmbainrot says:
from my experience you will want to re-enforce the balsa with glue (kinda like fiberglassing) and insure that the grain is at a 90 degree angle to the rocket. If you have the grain parallel to the rocket it will split and fall off during flight, sending the rocket in a uncontrolled spiral with no predictability.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ClCrow
