Easy How to Mold Cast and Duplicate Your Wood Carving With Concrete
Introduction: Easy How to Mold Cast and Duplicate Your Wood Carving With Concrete
Learn the easiest method for duplicating your wood carvings!
Step 1: Prepare Your Carving
Shellac or any appropriate sealant can be applied to the carving. Once the sealant has dried the carving should be glued to the bottom of a mold box/container to prevent it from floating. Then coat the carving with a very light coat of mold release, if excessive amounts are used wipe away the extra.
Step 2: Create Your Mold
Melt the ComposiMold in a microwave, double boiler, chocolate melter or any other method that does not allow the ComposiMold to be in direct contact with temperatures exceeding 200°F. Once the ComposiMold has melted spray your carving with a medium coat of Bubble Buster and pour the ComposiMold while the Bubble Buster is still wet.
Step 3: Prepare Your Mold
Once the mold has cooled and feels like rubber cut down one side and stretch the mold so you can pull the carving out. Once the carving is removed seal up the cut with tape. Now spray the inside of the mold with a very light coat of mold release (cooking oil will work).
Step 4: Prepare and Pour Your Casting Material
Use a mix ratio of one part water to two parts ComposiStone. Next force the ComposiStone down the legs using a syringe or just vibrating the mold. Once the mold is full tap the mold until the ComposiStone smooth’s itself out.
Step 5: Remove the Model and Enjoy
Remove the ComposiStone model from the mold approximately two hours after pouring. Then paint and enjoy your new creation!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    If you want even better results, you can use a bigger jar with a lid (needs to be airtight). After pouring the ComposiMold, apply a vacuum to the innerts of the mold (by drawing air out of the jar with a hole in the lid you previously made). This expands the bubbles and allows them to rise away from the object and flow to the top.
    This also removed big parts of trapped air in small details like the face of the figurine.
    Better mold = better cast = more joy :)
    Thank you for your suggestion! Just make sure ComposiMold stays up to temperature the entire duration a vacuum is being applied. Out of curiosity what types of objects do you mold and cast?
    I didnt mold and cast lately... Made it as kid (15+ years back) but remembered this lesson from my dad... :)
    May soon cast plastic-resin for a bowgrip of my W&W InnoMax.
    I like this a lot! I've just gotten into casting cement myself. I always love what detail can come out! Great job!
    If you get a chance I would love to see your projects, Cement casting is so much fun! Thank you for your positive comment!
    Oh for sure! I'm actually making a fire pit right now that I hope to be up in the next week or so.
    This an excelent solution to my sphereical wood carving problem!
    I can't wait to try this out!
    Most excelently done my friend!
    Thank you so much! Please share your projects with us anytime, we would love to see what you create!
    I will be sure to get right on that! ^^
    ComposiStone works great with ComposiMold, and plaster of Paris works best with ComposiMold when an exact mixture of 73% plaster by 27% water by weight is used. If scales are not available, make the mixture pourable but as thick as possible.
    Thank-you for the comments
