3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy, Inexpensive Doggy Door in a Screen Door
Step 5Attaching the Flaps
Attaching the Flaps
  • last photo ←
I used rivets with washers to attach the flaps onto the support bar.
First I put the flaps approximately in place, then I overlapped the flaps to get the most coverage.
Then I folded the top of each flap across the top of the bar, so it would be attached in two places.
I used the Barge cement to glue the extra pieces of flap to the top for reinforcement.
Then I pierced the flap with an awl close to the edge of the door (to make a hole), put the rivet w/washer through the hole, put a washer on the far side, and used the pop rivet gun to attach it.  This might have been a little easier with a spring clamp to hold it all together.
I did this on both right and left sides.  Then I added a rivet in the middle.  Then I added two more, one on each side.  At that point it was well-secured.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:galadriel(Lorien Stable Saddle Fitting)
