3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wicked Laser Case
Wicked Laser Case
New pictures added and a new video added.
The video shows how the case is water proof. I was so confident with my case that I put my $150 laser in it.
This instructable will tell you how to easily make a heavy duty laser case and a regular laser case.
It is meant to replace the bulky laser cases that often come with the laser. Tthis case will prevent the laser from getting scratched up and the lens from getting full of dust and dirt. It can also protect it against drops, water, and even having it ran over by a car.
Step 1Picking materials
Picking materials
First you will need to decide if you want to have a heavy duty case, which will be bigger yet stronger, or a regular case, which will be smaller but not very strong.
For the heavy duty case you will need the following:
- Laser point. WickedLasers.com sell some awesome high powered lasers.
-6" long 1/2" I.D. (inside diameter) PVC Nipple.
-(2) end caps that fit snug on the end of the pipe.
-Styrofoam packaging from anything.
-A knife, or razor blade.
-plastic glue (optional)
-plastic paint(optional)
-Teflon tape(optional)
In the picture you can see the threaded end caps I used, and the tube that I used.
IMPORTANT The inside diameter of the pipe might be different for different lasers, so check your laser diameter before you buy the material
When choosing the end caps, if you decide to use threaded end caps like I did, then you don't have to worry about how tight they fit onto the tube/pipe, but If you aren't using threaded end caps then you will need to make sure that have least one of the end caps can come off easily, but not too easy.
How to choose which end cap you want:
Threaded end caps:
- Heavy duty
- Make the laser case bigger.
-The removable end cap won't slip off on accident.
- The laser case is water proof.
-Overall design looks better.
Non-threaded end caps:
-Not as heavy duty
-Laser case is smaller.
-Removable end cap can slip off on accident.
-Laser case is most likely not waterproof.
-Overall design looks plain.
23 comments
Nov 6, 2009. 2:44 AMdanielpower says:
I can buy  a 150mw waterproof green laser pointer with $150.
Jul 22, 2009. 3:46 PMmgysgthath says:
If you want a great laser (the best really) for less (a lot less) money than a wickedlaser go to optotronics.com they are top quality and a lot cheaper. Consider also dealextreme.com which has 5 to 200mW for $10-$40, and the 200mW is a burning/cutting laser. The RPL series from optotronics is like a flame thrower compared to a match, with any other brand, including Wicked's $1699 laser, which is woefully inadequate next to the RPL (and pricier). Just a tip for anyone wanting a real quality laser. Good build though!
Jul 24, 2009. 12:25 PMmgysgthath says:
In fact I own a wickedlaser and it is quite subpar compared to even the "crap" lasers from DX. You're right there is no IR filter, but if you're silly enough to use a >5mW laser without safety goggles for the wavelength and furthermore shine it in your own eyes (IR is not blocked by most goggles), you deserve what you get. Optotronics makes both the Pen style high powered (higher than WL) lasers, and also the RPL professional series with increased build quality and heat dissipation. Just trying to inform people that WL is not what they're cracked up to be. They are good lasers, but definitely not worth the cost.
May 31, 2008. 3:25 PMcheating-master says:
(removed by author or community request)
Nov 28, 2008. 5:44 PMSupercoke says:
well it depends on which laser you like, if you like big powerful cheap lasers, then I would recommend dragon lasers, but as swargy said "with wicked lasers you get what your paying for", and also if you want a laser just to point with i recommend going to radio shack
Jul 9, 2008. 4:27 PMqballcat says:
i like dragonlasers.com but wicked lasers is good too
Oct 23, 2009. 12:34 PMColonel88 says:
i like .99 cent lasers because they're cheap and do their job.
Oct 18, 2008. 3:34 PMjunits15 says:
wtf wicked lasers is soooooooo expinsive!
Oct 19, 2008. 7:06 AMjunits15 says:
actuly the site i told you about before has a new site www.aixiz.com the site isnt finished yet so it can be a little slow at times.
Oct 19, 2008. 6:50 AMjunits15 says:
actuly i prefer to buy the diodes from axiz only downside is i have to make some sort body for them but they are good for things like lego laser writers.
Oct 20, 2008. 11:43 AMjunits15 says:
hhm mabey ill consider getting one! :D
May 17, 2008. 2:08 AMmarkxp4000 says:
its cool
Dec 29, 2007. 8:52 AMHelioplasma says:
Hey its very nice ! good job ! Although it would be even more perfect if you put an on/off switch to be able to use it in a pool or something like that..
Dec 3, 2007. 4:55 PMGorillazMiko says:
nice instructable! if i get a laser, which might be soon, ill do this. (favorited)
Dec 3, 2007. 12:46 PMFathomBoy91 says:
its a pretty cool instructable... now u gotta make some crazy cool design on it!
check out mine and best of luck!
Wicked Light Show
Dec 1, 2007. 6:20 PMCaptainCrash says:
I need a new case. The one that came with the laser wont stay closed.
Dec 1, 2007. 3:05 PMtrooperrick says:
nice instructable, I think i am going to have to make one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:swargy
