3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wicked Laser Case
Step 3Assembling the laser case
once you have all your parts you can start to assemble your laser case.
The following steps are the same for both the heavy duty laser case and the regular laser case.
If you have threaded end caps use the following steps:
1. On one end of the pipe put Teflon tape around the threads in a clockwise direction. This only has to be done if you want yo make your case waterproof.
2. Firmly tighten one end cap onto the Teflon tape side of the pipe.
3. If you didn't use Teflon tape then it doesn't matter which end of the pipe you screw the end cap onto. If you want you can also apply a small amount of plastic glue to the threads to keep the end cap from coming off.
4. Make sure your laser fits inside the pipe and doesn't stick out the open end.
5. Screw on the second end cap, but not too tight
If you don't have threaded end caps, use the following steps:
1. Apply glue on the end of the pipe and firmly push on the end cap.
2. Make sure your laser fits inside the pipe and doesn't stick out the open end.
3. Press on the second end cap, and make sure that this end cap can easily be removed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:swargy
