3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Kayak Trailer/Cart
Hello fellow kayakers! Here's a pretty simple kayak trailer/cart that requires very few materials and tools to make. The great thing about this is that it can be tweaked and redone to suit any kayak and attach almost anything from bikes to ATVs. PLEASE feel free to leave all criticism, ideas, and comments on here. I'm only 16 and this is my first instructable so everything helps. Thanks alot!
*EDIT*
Today this was tested with a 100lbs person sitting  in the back while I lugged it around. It held up quite nicely. The only thing I might change is  the space beteen the tires and the kayak. If she tilted a little bit the wheels would rub a little bit.
Step 1Materials and Tools
Materials and Tools
MATERIALS
Now, every kayak will be different. So your sizes will change depending on your kayak. Heres a rough list of what you'll need.
2- 12" cuts of 2" PVC piping.-I used the thick walled gray stuff
2- 25" cuts of 1/2" PVC
2- Lawn Mower Tires Or Whatever You Have
12" of 90 degree bend metal plus some for later. (See Picture 2)
2- 3" Bolts and nuts to go with it
The length of my 2" PVC is based off the distance of my scupper holes. For sit-in kayaks, just make sure its at least 3/4 of your kayaks width or more, and the 1/2" might have to be longer than 25" so you have enough ground clearance.
TOOLS
Drill-For Putting Holes In PVC and In Metal
Saw capable of cutting through PVC (ie; Bow Saw, Hack Saw, etc.)
Welder-To weld a wall on the angled metal so your wheels can attach
Grinder-To cut out square to be welded on
NOTICE
Now I use the angled metal and such for strength. You could very easily just take a long axel and string it through to your wheels. It would make things a bit easier, but I'm a complicated man.
3 comments
Aug 14, 2011. 6:57 AMpunchedname says:
Well done! This trailer should win for its creativity alone. Good luck!
Aug 9, 2011. 2:38 AMbertus52x11 says:
Smart!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kingsmanname
