3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Koolaid Microwave Wool Dye Technique
Easy dye project to use on protein fiber including wool and silk. Use your microwave and in a matter of minutes have art ready fiber for felting, weaving, spinning-project ready!
This is so easy! It just couldn't be any easier! If you have some wool or silk fiber you want to color-this is the way to go! All you need is simple equipment you probably already have in your kitchen and some protein fiber. I like using the powdered drink mix as dyes. They work well, have strong, vibrant colors. Inexpensive to use and are readily available. Safe to use in your own kitchen cookware. Requires no special additions or equipment. Easter egg dyes can also be used.
Step 1Easier than pie!
Easier than pie!
Supplies you need-Microwave safe bowl(s), Colander, strainer or salad spinner, Wooden skewer, Rubber gloves (optional), Mesh laundry bag, Unsweetened powdered drink mix in desired color(s), or Easter egg dye, Microwave, Drying rack, Protein fiber- wool or silk fiber
Gather your supplies. Add powdered drink mix to hot water in microwave safe bowl I use Pyrex. Stir to dissolve with skewer. Use 1-2 packets of powered drink mix in desired color, depending on amount of wool used and desired color saturation. Moisten wool with hot water under faucet before adding to dye bath. Squeeze out excess water and push down into dye bath with skewer or hand protected with rubber glove. Or dye your fingertips like I have done!
39 comments
May 21, 2012. 12:24 AMpaqrat says:
Very cool idea. I wish it worked with cotton.
Apr 18, 2008. 12:25 PMincorrigible packrat says:
Colourfast and everything? Kool! My brother just bought 54 sheep (I'm not joking here), so I might have some raw material... Now I just need 10000 Kool-aid.
Apr 18, 2012. 7:14 PMbouder says:
.... and there are Polypay sheep, that provide both wool and meat! LOL! Sorry, couldn't resist. ;-)
Apr 21, 2008. 6:47 AMincorrigible packrat says:
They're meaty sheep, I'm not sure what breed. I think meat sheep still require shearing (except for hair sheep). The wool probably wouldn't be so nice for spinning, but should make decent felt. I'd probably want to wash the poo from the wool beforehand, as the sheep appear none too clene (I elect not to comment on whether, or not, the shepherd is shitten). Washing might also be helpful in removing some of the lanolin, which I imagine would interfere with uptake of the waterborne Kool-aid dye.
Jan 31, 2012. 6:08 PMsophianw says:
hi! thank you soooooooo much for sharing this, but i do not have sheep or a llama, that i could shear but could i do this with white yarn
Jun 17, 2011. 4:43 AMOrIsIt says:
Minecraft anyone?This just reminded me of minecraft
May 4, 2011. 4:36 PMNaturalCrafter says:
The frog made from a wool sweater is great. You should do an instruction just on making him. Wonderful.
May 12, 2011. 6:13 PMNaturalCrafter says:
Great...I am looking forward to seeing them.
May 4, 2011. 1:20 AMNaturalCrafter says:
I have a bunch of white wool fiber that I am just loving to try this! Thanks much. Infact I have some blue koolaide that would be neat! Thank you Thank you!
May 4, 2011. 3:48 PMNaturalCrafter says:
I have been wanting to try something like this for awhile. Though I now have a list of projects. I just finished tatting a doily..so cross that off, and I also working on the second sock to go with the one in my photo to have a matched set. Should I try to spin the fiber first and then dye it or dye it and then spin it? I could try it both ways and see what happens.
Apr 20, 2009. 7:37 PMJohnMichael says:
How is vinegar (acetic acidic) going to neutralize citric acid? Did I miss something?
Jan 27, 2010. 11:16 AMSallyOH says:
If this is an acid dye technique, you need a mordant to help the fibers fully absorb the dye, and to set the dye into the fibers so that the dye is colorfast and will not run should the work ever get wet again. Citric acid OR white vinegar does that. I would advise anyone to use one or the other. It should be added after the dye begins to absorb (although I have not done the overdyeing in a microwave.) When overdyeing on the stove top, the wool and dye are combined in the dye pot for about 30 minutes, then the vinegar is added and all the color gets absorbed into the wool during the next 30 minutes in the dye pot. The heat distribution/temp in a microwave is different, so I am unsure as to the timing of adding the mordant agent. But I would definitely use one.
Oct 8, 2009. 2:04 PMkckthx says:
 Awesome!  I've always wanted to try dying with koolaid.  Do you know if you'd need to re-card the wool before spinning it?  I'd be afraid putting it in the drying would agitate it a good bit.
Jul 11, 2009. 5:49 AMjustkim says:
Love the idea of the Koolaid method. Will it work on synthetics, i.e. nylon or poly?
Aug 4, 2009. 10:26 PMki10 says:
Nothing really does well, and I'd avoid a method with this much heat on synthetics.
May 13, 2009. 2:46 AMnatamon says:
I am so excited about this knowledge! Just sent you a private message asking for a little more info-thanks in advance!! :D
Apr 20, 2009. 7:38 PMJohnMichael says:
That is interesting. Thank you for sharing.
Apr 23, 2008. 9:23 PMBeautifulStranger says:
Does the wool shrink or felt in the hot water?
Apr 24, 2008. 8:24 AMBeautifulStranger says:
Thank You. I never expected an answer:>)
Apr 23, 2008. 8:34 PMYerboogieman says:
lol, kool.
Apr 22, 2008. 4:09 PMNoadi says:
Hmmm... Now I know an easy way to dye all the llama fiber I'll have as soon as mine is sheared in a couple weeks.
Apr 18, 2008. 7:42 PMBrowncoat says:
Could you use this concept on cotton?
Apr 17, 2008. 1:25 PMreedz says:
Great Instructable, does the dye wash out after a while?
Apr 16, 2008. 5:00 PMGorillazMiko says:
Nice method! I like the last picture, that ball that is red blue and green looks cool. :-)
Apr 16, 2008. 7:50 PMMatthewMetcalf says:
Does the flavoring absorb into the wool too? That would make for a great hiking sweater...just wring out the sweat, add sugar and voila....clear koolaid.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:myrrhmaid(Kelly Graphics)
Fiber mad woman living in the mountains..
