3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Koolaid Microwave Wool Dye Technique
Step 2Zap On High!
Zap On High!
Microwave on high. Cook at 2 minute intervals for 6-8 minutes for 2 quart bowl or until all the color is absorbed into the fiber. Here I've moved the wool aside in the bowl so you can see that the water is clear as the wool has taken up all the color. This is exactly what I want to happen! The heat of the water bonds the color to the fiber making it colorfast. It won't fade with washings. This is a permanent dye. Use hot pads to remove from microwave. Be careful! It gets really hot! Use the skewer to push the wool back into the water as it cooks, if needed, stirring minimally. Agitation of the fiber will cause felting at this stage. You can also place a microwave safe saucer on top of the fiber to submerge fiber, if needed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:myrrhmaid(Kelly Graphics)
Fiber mad woman living in the mountains..
