Easy Lampwork Bead Earrings
872
6
Published
Introduction: Easy Lampwork Bead Earrings
About: I am a teacher outside of Boston and I love making cool stuff! Any prizes I'm lucky enough to win will go directly to my classroom (when appropriate) where I teach 6-12th grade English & Social Studies (...
To make these earrings all you need is a pair of needle nose pliers, lampwork beads, and ball head pins. The inspiration for these earrings came from a pair of similarly styled bead earrings my husband bought me a few years ago from an artisan market. I loved them so much I went back for another pair. They are very simple and easy enough to make that you can have a wide variety to go with any outfit. They're also classy enough for any occasion.
Step 1: BoM
Lampwork beads
Headpins, wire (common gauges are 20, 21, 22)
Pliers
Mandrel or wire jig w/pins
Earring backs (optional)
Jewelry glue (optional)
Step 2: Dangly Earrings
First, I recommend practicing shaping ear wires with some scrap wire before making final pieces. It just a good idea for getting the hang of working with wire. When you're ready, you want to select your beads and test them on the headpins to ensure they won't slip through.
You can free hand shaping wires, but I've found using a jig gives you a smoother curve. Choose one of the thicker pegs and wrap the wire around it until you have the desired shape, then grab a smaller peg and wrap the end of the wire going in the opposite direction to make a little tail. Trim as needed.
Step 3: Bead
When your earring is made, slip your bead(s) on. For a little extra security you can add a dab of jewelry glue/cement to the back of the bead and let dry. This is totally optional, I've yet to have a problem with a bead sliding off.
Step 4: Studs
For studs, you can simply bead your wire and then snip off the end (make sure the wire w/the bead is long enough to go through your ear and have a backing attached). For studs I definitely recommend securing the bead with cement/glue and using an ear backing.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
