3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Lego iPod Speaker for less than 2 $ !
My sister wanted some speakers for her iPod. She showed me speakers she liked. It was some
speakers made with Lego... When I looked at the price...... 25+ bucks for a piece of Lego with some speakers.... I told her I could make a similar thing for ... free or almost... The only difference would be where the speaker would be located... on top instead of the bottom.
Step 1Before Begining
Here what you will need to do the project :
- Lego block (will contain speakers) ( I took a 8 x 2 x thick lego block) - Found in my closet
- Lego block (will act as the back plate) ( 8 x 2 x thin) - Also found in my closet.
- 2 small speakers - I ordered 2 samples from Project Unlimited (Part number AS01508MR-R)
- Headphone jack (1/8") - Old one from a extension cable
- Hot glue
- Soldering Iron, Vacuum plunger, solder
- Dremel tool
- Needle-nose pliers, wire cutter, cable stripper
- Wires (you could use so telephone wires, would get the job done)
- Safety Glasses Important !!!!
- Spare time
- Patience
Optional:
- Multimeter/Continuity tester
Cost of this project : .... 0 $ USD... which is also 0 $ CND or 0 euro... God I like 0. As I said earlier, I found my Lego block in my closet.... I had an old extension cable for the audio jack and I ordered sample speakers... so, every components were free... :)
But, I guess if you didn't have an audio jack... this could add up... 1 or 2 bucks... or 10 minutes of hard-looking in you house to find a broken pair of headphones.
64 comments
1-40 of 64next »
Mar 24, 2012. 1:51 PMGASSYPOOTS says:
speakers cast more than $2
Feb 18, 2012. 11:45 AMiApple guy says:
Your URL is not working for me. It says... 404 file or directory not found. Please help! Thanks!
Feb 18, 2012. 11:43 AMiApple guy says:
Your URL is not working for me. It says... 404file or directory not found.
Feb 18, 2012. 11:42 AMiApple guy says:
Yor URL is not working it says... 404 page or directory not found
Nov 14, 2011. 4:24 AMelco_chan says:
Just ordered the speakers!!! will post pics soon!!!
Dec 28, 2010. 5:58 PMgunman15 says:
i just got something different
Apr 18, 2010. 1:52 AMmenace4 says:
Should I Put My real name in the sample speakers  requesting page?
and what must i type in the "title" field?
Jun 12, 2010. 1:54 PMTheBigT92 says:
What did you put in for the application part of your sample order?
Mar 16, 2010. 9:49 AMdhvinay says:
can u please tell me from where u ordered the speakers ?
And if u pls send me the url to the website...
Jan 24, 2010. 1:36 PMTSC says:
cccccccccccccccccccccoooooooooooooooooooooooooooooooooooooooooooooolllllllllll!!!!!!!!!!!!!!!!!!!!!!1
Apr 26, 2009. 6:34 PMminimas1323 says:
What did you put for the your company name when ordering the speakers?
Oct 7, 2009. 10:21 PMcellopants says:
[Your city name] Audio works.
Jun 8, 2008. 2:31 PMlil_timmy1990 says:
Super glue the back on. That would surely hold it.
Jul 21, 2009. 8:48 PMLargePaperCup says:
try filling the brick with speakers with hot glue, let it dry and file the edges of the back pl8 and then super glue it
May 24, 2009. 6:38 PMpryrofreak119 says:
i use plyers to get that stuff out you just stick one of the tips inside the hole squeeze and twist and the excess plastic i use a file
Apr 26, 2009. 4:33 PMBig_buck_hunter says:
Hey when u ordered the sampels were they free thanks
Apr 7, 2009. 4:03 AMAzraelUK says:
The iPod connector does give you line out, much the same as the headphone jack. That'd make for a device more similar to the one your sister was after.
Mar 11, 2009. 6:29 PMminimas1323 says:
nvm it just worked for me. thanks
Mar 11, 2009. 5:55 PMminimas1323 says:
when i clicked a request for a sample speaker it said that there was an error
Feb 26, 2009. 7:45 PMwangtrevor says:
can u use a soder for this step?
Feb 26, 2009. 7:42 PMwangtrevor says:
how do you get the sample speakers?
Jan 10, 2009. 6:52 PMKyda says:
Like poi_pai said though, if i were to use earbud speakers, would the sound be the same as regular earbuds in a differen visible form or would it be, well, loud?
Feb 26, 2009. 7:59 PMwangtrevor says:
how did u get it free fake aplication? could you help me email me a t wangtrevor@gmail.com (btw u have a very good mind thinking of how to make this )
Feb 26, 2009. 7:38 PMwangtrevor says:
where do u get the speakers?
Jan 25, 2009. 6:42 PMpshinoright says:
Ay if u want something a little louder try making these outa some of the bigger "duplo" legos. Then you would have more room for bigger speakers. xP cool idea
Jul 19, 2008. 2:56 PMpoi_pai says:
Forgive me, I'm about as techno-savvy ar a jug of milk. Is there a difference between the speakers you used and the ones inside the earbud headphones, and if yes, what is it?
Dec 26, 2008. 4:00 PMJa2Pc says:
Hey I know how to increase the volume, if you have an iPod go to your iTunes playlist and select all the songa, then right click and select "GET INFO" then a box will pop up, in the box select the option box and in there, there should be a volume increaser it is defult set to 0% so boost it up top 100%, sync your ipod and TADA!!! Hope that helped, visit my website www.krunched.com/popartme
Jul 19, 2008. 6:16 PMpoi_pai says:
I guess my reason for asking is I'm just wondering if the sound was good, or if it was quiet and on the tinny side.
Feb 26, 2009. 8:01 PMwangtrevor says:
how loud would the sound be the sound of mosqutios next to your ear? earbuds 3 inches away from your ear with full volume ect.email me at wantrevor@gmail.com l
Nov 11, 2008. 2:59 PMtba469 says:
I liked this project, so I got some samples. Just finished trying it out, and I have to admit, I was a little disappointed in the volume of the speakers. I knew I wasn't about to get anything too great, but in a quiet room, I could still barely hear them. I'm going to try again, but with some headphone speakers that are about twice the size. Thanks!
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Agurri(OliLaf.com)
I'm just a regular guy who likes to build stuff, discover things... you know the drill. I'm a bachelor in electrical engineering. I love learning new things everyday. Oh, and I like cookies....
