Introduction: Easy Make PCB Board
HI Guys I'm Steve From India
And Today i'm Going to Show to How To make a PCB Board.
Click Here to See The Video
Step 1: What You Need
Step 2: Now Come to Work
I'll do step by step
- Print Out Your PCB layout in photo paper with Laser Printer Only
- Cut The Copper Clad in The Same size to match the layout dimension
- Now Put The Paper onto The Copper Clad and Press With The Hot IRON
- Now You Need a Bowl of Water
- Put The PCB into The Water Let it soak For Around 30 minutes
- Now carefully Remover The Paper From Board
- After Removing The paper
- You need to put some of Ferric chloride in a container with little water
- Now put the PCB into the Ferric chloride Solution
- After 20-30 minutes You Are done to take the PCB OFF
- Now clean the PCB with some water
- Now You Need a acetone and cotton ball to remove the black part
- After Doing that you need to drill The holes for The components
- Now Place your components and solder it
Step 3: You Are Done
- Your PCB is Competed Your PCB will Look Something like This
Circuits Contest 2016
