Easy Outdoor Cinder Block Benches
12,105
157
14
Published
Introduction: Easy Outdoor Cinder Block Benches
About: Chip's Wood Shop is all about rewarding and enjoyable woodworking projects and ''use what you have''solutions to make all kinds of fun and useful things. We are a participant in the Amazon Services LLC Asso...
We admire the bench on our neighbors' front patio, so we decided to make some for our back patio along the fences. These are easy for anyone who can carry, glue, and paint cinder blocks and wood posts.
In the interest of time, we bought some seat cushions (not shown), but I'm sure some of you would love to make those, too.
Step 1: Measure and Plan
Here, I'm showing the finished bench to illustrate the goal. We divided the length of fence where each bench would go into segments about 4 feet (1.3 m) wide. So one bench needed both ends plus one support in the middle. The other needed two supports in the middle.
Step 2: Tools and Materials
Tools
  • caulk gun
  • Hand saw , or circular saw
  • drill (if joining multiple posts for length)
  • clamps
  • paint sprayer or roller, brush, etc.
Materials
  • cinder blocks (4 per support)
  • construction adhesive (one tube glues about 3 supports)
  • primer
  • paint
  • wood posts (5 per bench)
  • carriage bolts, nuts and washers (5 per bench, if joining multiple posts for length)
For each support, you need four regular double cinder blocks (8x8x16 inch ~20x20x40 cm) and one single (8x8x8 inch ~20x20x20 cm). You also need wood posts long enough to go through the supports in the ends plus a little extra. I have mine extending 6 inches (15 cm) past each end. The longest posts we could get at our stores are 12 ft (4m) long. Since we need about 17 ft on one bench, I decided to join posts inside the blocks with half lap joints as explained later.
Step 3: Glue the Blocks Together
First, I glued together the three cinder blocks stacked to create clamping pressure. After the glue cured, I turned them upright (two holes high and three holes wide) to glue on another block on end for the back. Finally, I glued in a half-block and used clamps to apply pressure to the joint in the horizontal direction (last photo in this step).
Step 4: Cut Half-laps (if Needed)
As I mentioned, I needed longer posts than I could buy, so I decided to hide the joint inside one of the supports. I cut the posts with an extra 3.5 inches of length, then used a circular saw to cut the half-lap as shown. I lined the posts up and cut them all at the same time. I used a clamp-guide to cut halfway through 3.5 inches from the end. I used a 1/4 inch thick board as a guide to cut across the ends. Then I realized it would have been easier to limit the overlap to the max depth of my circular saw (which is more like 2 inches, not 3.5)!
Step 5: Keep Cutting (if Not Wise Enough to Avoid This Step)
My punishment was to cut the rest of the way with another saw. I used my grandpa's hand saw for one, then decided I didn't want that much exercise, so I cut the rest with a saber saw. Again, if you only overlap the posts by the max depth of the circular saw, you can avoid this step.
Step 6: Paint/stain
I used a HVLP paint sprayer to prime and paint the blocks. I tried the sprayer for staining the posts, but found I liked the control I had with a roller better.
Step 7: Install the Posts
I cut out some pieces of cardboard as shown, then rolled them up into square tubes and installed them in the holes in the blocks as sleeves to protect the finish when inserting the posts. After inserting each post, I pulled out the cardboard tubes and put them in the next row of holes.
Step 8: Join the Half-laps (if Needed)
Where I needed to join posts, I drilled through the middle of each joint and installed a carriage bolt, washer and nut. Then, I slid the joint into the block, where it wouldn't show.
That's basically it. If you don't have to join posts, you can see how it's even simpler. We had three generations over to the house for our first party on our back patio, and the bench was great. As I mentioned, we ordered some cushions to go on it. We found it was fine for seating, although a little low. With cushions, the height is great and overall more comfortable.
Step 9: P.S.
If you like this style of step-by-step instruction, please share with others and subscribe, so you'll be notified when I post more. If you have questions, please post them in the comments. I will try to answer and probably update the instructions, too. Read about more of my woodworking projects and tools at ChipsWoodShop.com.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    Are there adhesives that can replace mortar for a brick wall?
    14 Comments
    The Geometry/Symmetry is outstanding - eye-catching. Color scheme does not hurt either!
    Your wrote a line that caught my eye as well: "Again, if you only overlap the posts by the max depth of the circular saw, you can avoid this step."
    Frankly, if the saw's depth of cut is less than one-half the thickness of the lumber, you cannot create a half-lap joint at all.
    Check to see if your saw will take a 7.5" blade some may take an eight-inch blade.
    Put the post up an sawhorses with the 'mating end to your RIGHT. Set the depth, then make the 'left-most" cut, then and other a quarter to 3/8" toward the end of the post and repeat until the next cut would be off the post.
    Take a hammer and hit the pieces left standing and they will fall away. Then take a chisel and 'clean up' the lap by removing what remains. Search Cutting Half-Lap Joints on YouTube several examples there.
    Thanks. You are right that the saw needs to cut at least half the thickness. I was referring to the amount of overlap. If you cut the shoulder too far back for your saw to reach from the end, you need a different saw.
    This looks like a good and easy project. Do you think there would be any safety/stability issues for a single bench in a yard with sandy soil and no back wall/fence? Thanks for posting!
    Our bench doesn't ever touch the fence. It's on a concrete patio so it doesn't even move when my boys climb on it and walk along the back. I expect it will be pretty stable in your yard, but if you have grass or weeds, it might be hard to cut under it.
    A point....... Cinder blocks were given a trial after WWII and found lacking. They have not been manufactured in over 60 years.
    I imagine what you used are CONCRETE blocks. Concrete, not cinder and not cement.
    However, I should not omit my kudoes on a job well done.
    I was thinking a little low seat height but if you ad a 2/3 in cushion
    Right. My wife ordered these 4" cushions that work great!
    The blocks appear to be convenient for holding drinks, etc
    Yes. So far we've used them to hold books while reading to the boys.
    Pretty nice project. I wonder if plastic type wood products would work equally well? Then you would never have to worry about them even again. I like your layout. Kind of looks like stadium seats. Thumbs Up!
    Thanks! I suspect any deck-building materials would work as well.
