Step 4Yay! More Foam!
First, once your "cradle" has been cut out of the base, it will likely be a little rough, as the first cut is never perfect. FEAR NOT! we have the technology, we can make it look good again.
Remember that other sheet of foam? Chances are, if you frequent this website, you know where I'm going with this...
Simply cut the sheet into a square small enough to cover the most visible surface of the removed area (fig.1)
NOTE: These two surfaces (foam & foam) are fiends for hot glue, as in, glue it ONCE, cause you're gonna be RIPPING it apart to re-do it.
Add Comment
