Remove these ads by
Signing UpStep 1: Stuff
Ruler
Paracord (about 3.5 feet)
Keyring
Lighter
Scissors/Pocketknife
About 5 mintues
If this was made into a kit, it would include 4 feet of paracord, a keyring, mini-scissors, a cheap plastic ruler, and possibly a cheapo lighter.
Visit Our Store »
Go Pro Today »
You can find a few more paracord keychain instructions on my site.
I modified it by using an alpine butterfly loop at the end rather than a keyring, if you make the loop about 1" to 1.5" inner diameter you can pass the fob through it to attach it to whatever you like after the fact.
I use a hollow needle called a "fid" to pull the ends under the front and back of the fob, then cut them as short as possible with a pair of paramedic scissors (the only scissors that I've found will cut paracord cleanly), although I've also used a hot knife tip on a gas soldering iron.
Then I bend and wiggle the fob a couple of times and the cut ends disappear underneath, It's a much neater finish than cutting and melting although you have to justify the cost of the fid (about 8GBP).
Happy paracording!!
Malc
