Easy Paracord Survival Key Fob
 by Adambowker98
Featured
Here I will show you how to make an easy paracord key fob. It is used for survival because when unraveled, you get 4 feet of paracord that has been tested to hold 450 lb.!!!!!!
Step 1: Stuff
What you need:
Ruler
Paracord (about 3.5 feet)
Keyring
Lighter
Scissors/Pocketknife
About 5 mintues
If this was made into a kit, it would include 4 feet of paracord, a keyring, mini-scissors, a cheap plastic ruler, and possibly a cheapo lighter.
Step 2: Attaching to the keyring
To attach to the keyring:
  1. Fold the paracord piece in half
  2. Pull the folded paracord through the keyring
  3. Bring the bottom pieces up around the keyring and through the loop at the top
  4. Tighten
Step 3: Weaving the fob
The easiest way for me to explain this is with pictures, so just look at the pics and read all the captions.
Step 5: Go use it!
Attach it to your keys! Now when you reach in your pocket to get your keys you can just grab the fob! And if you get into an emergency situation, you can unravel this for 4 feet of extra-strong paracord!
Thanks for looking! If you make this, post a pic in the comments so I can see how you did!
mark_well says: May 22, 2013. 8:56 AM
A decent design, bases on the survival bracelet snake knot pattern.
You can find a few more paracord keychain instructions on my site.
hburkett says: May 10, 2013. 3:59 PM
Thank you for posting this. This is exactly what I was needing.
must_ache says: Apr 23, 2013. 11:14 PM
Thanks for the great guide, somehow I've been unable to get this simple weave through my head after a few videos and other guides.
I modified it by using an alpine butterfly loop at the end rather than a keyring, if you make the loop about 1" to 1.5" inner diameter you can pass the fob through it to attach it to whatever you like after the fact.
caleb44 says: Apr 2, 2013. 5:22 PM
how do you make it with two colors?
jcarlson4 says: Dec 1, 2012. 11:17 AM
Very easy instructable to follow, thanks.
Adambowker98 (author) in reply to jcarlson4Feb 21, 2013. 3:43 PM
Nice job with your fob! I like that camo color!
jedired says: Nov 30, 2012. 5:50 PM
Thanks for the instructable.
Adambowker98 (author) in reply to jediredFeb 21, 2013. 3:43 PM
No problem! The fob looks great!
ROOKIE49 says: Jul 12, 2012. 8:19 PM
Could you show how to connect to plastic buckles
Adambowker98 (author) in reply to ROOKIE49Oct 23, 2012. 6:00 PM
Try another paracord bracelet instructable. They usually show how to tie to a buckle. It's basically the same thing as putting it on a keyring.
mayfair2005 says: Oct 23, 2012. 4:32 PM
Turned out fairly nice for my first try, 3.8ft of paracord fairly loose so its flexible. I did over melt the end thou :/
Adambowker98 (author) in reply to mayfair2005Oct 23, 2012. 5:59 PM
Good job! Looks pretty good to me.
MalcolmB says: Sep 10, 2012. 5:16 AM
Hi All...
I use a hollow needle called a "fid" to pull the ends under the front and back of the fob, then cut them as short as possible with a pair of paramedic scissors (the only scissors that I've found will cut paracord cleanly), although I've also used a hot knife tip on a gas soldering iron.
Then I bend and wiggle the fob a couple of times and the cut ends disappear underneath, It's a much neater finish than cutting and melting although you have to justify the cost of the fid (about 8GBP).
Happy paracording!!
Malc
jamob says: Aug 14, 2012. 7:57 AM
I made one! it was difficult for me at first but once i got into it it was easy although it does look a little akward becuse i started knotting a bit too high
Adambowker98 (author) in reply to jamobAug 14, 2012. 8:55 AM
Can you post a pic?
jamob in reply to Adambowker98Aug 14, 2012. 10:49 AM
As you can see its a little short but thats my fault for putting the knot a little higher than you said
Adambowker98 (author) in reply to jamobAug 14, 2012. 11:55 AM
Oh, that doesn't look that bad! Having it shorter like that actually gives it some more flexibility at the top.
mmichener says: Aug 8, 2012. 4:51 PM
I have a wood burning tool that I use to melt the ends, works like a charm.
Adambowker98 (author) in reply to mmichenerAug 8, 2012. 6:02 PM
Great idea! I have a soldering iron and wood burning tool, but have only tried burning the ends with the soldering iron.
agent-0008 says: Jul 14, 2012. 4:35 PM
if your using twice the paracord you measure twice the length, right?
Adambowker98 (author) in reply to agent-0008Jul 14, 2012. 6:02 PM
Yes. So 6ft of Paracord = 6 inch fob.
ROOKIE49 says: Jul 12, 2012. 7:14 AM
This the first Instructible that I could reilly follow and now I am making these like crazy for everyone. Good job Adam
Adambowker98 (author) in reply to ROOKIE49Jul 12, 2012. 8:08 AM
Thanks!
skwalter2 says: Jul 1, 2012. 7:46 AM
Really enjoyed making the key fob. I've made similar cobra weave bracelets before, and this was just as easy. I tried making each knot as tight as possible, so the entire fob is pretty taut. As with the paracord bracelet I made, using a soldering iron made melting the ends really easy. Thanks a lot!
Adambowker98 (author) in reply to skwalter2Jul 1, 2012. 9:38 AM
That looks awesome! I've had a soldering iron for a while, just never thought about using it to burn the ends.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
