The pictures might be a little blurry, it's because I took them out of the video I made on how to make it.
Check you the video tutorial!
Remove these ads by
Signing UpStep 1: Getting started
-Two pieces of 2" PVC Pipe (any size)
-One 2" Non-threaded PVC End Cap
-One 2" PVC Valve (not threaded)
-One Schrader valve (from an old bike tire)
Tools:
-A saw (to cut the PVC pipe to your desired length)
-A drill with a drill bit that is about the same size as the schrader valve
-PVC Primer and Cement
Visit Our Store »
Go Pro Today »
The video shows pressure at 20 psi. The projectile is a foam type ball we use in the pool. I purposefully tested this with something soft to avoid smashing the neighbors windows. I'm sure a heavy object with better/less wind resistance (aka an actual potato) could easily be sent down the block and do some serious damage.
Trick-or-treaters will be greated by a Blue Man at the door who will "launch" their treats into the yard. I really just need something to put it over their head and into the yard.
Requirements:
(1) I wanted it to sit on the ground so I didn't have to hold it.
(2) I wanted a smaller launch tube, but didn't want an 8 foot long 2" tube (which would approximately equal the same air volume as a 2' by 4" tube).
Changes and Comments:
I used a 4x4x2 junction and put the 2ea 1' by 4" on each end. Then I cut a lenght of 2" tube long enough to put the valve at a comfortable height. This also solved problem #1.
I used pipe that is rated to at 220 psi or more.
I still wish there was a better way to mount the valve. -- The valve is my weak link. I used Locktite which took 48 hours to dry, but it still leaks a bit. If I get much over 20 psi it begins to leak out faster than I can pump. I have some ideas on how I can re-seal this without cutting everything apart.
Thanks again for putting this instructable together.
-r
