Easy Powerful Crossbow
Published
Introduction: Easy Powerful Crossbow
This instructable will show you how to make an easy and cheap, yet powerful crossbow. It's pretty easy to build and it only takes 5-10 minutes.
Step 1: Materials
The materials you need will vary depending on how you want to build your crossbow and what you have available in your house. Materials: - A wooden board about a 1 1/2 feet long - Two wooden dowels - A rubber band Tools: - A drill - Lots of duct tape
Step 2: Making the Base
The base of the crossbow is the wooden board and it will need to be about an inch thick. Once you have cut the board you need to drill holes on each side to stick the wooden dowel in. Next you will have to glue the dowels in, you can use tacky glue or elmers glue, but I would recommend wood glue.
Step 3: Attaching the String
This step is very simple, all you have to do is cut the rubber band and tie each end on each wooden dowel.
Step 4: The Arrows
For the arrows all you have to do is cut the wooden dowel to about a foot and a half long and then you can shoot. Also if you want you can sharpen the arrows like I did.
Step 5: Now You're Done!
Now you are finished with your crossbow and you can personalize it anyway you want! (I attached the handle of a nerf gun in case you were curious.)
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Sadly, this isn't even a crossbow. It's just a bow, attached to a plank. A real crossbow has something to hold the stretched string in place, and a lever, to release it when you want to.
