Pressure Cooker Country Pot Roast
3,299
52
Posted
Introduction: Pressure Cooker Country Pot Roast
Easy Pressure Cooker Pot Roast
Hereis a recipe for a flavorful pot roast that melts in your mouth .The pressure cooker produces juicy, flavorful and extremely tender Pot Roast.
Ingredients:
1 beef eye of round roast or chuck roast, about 2 to 3 lbs.
Seasoned salt and freshly ground pepper, to taste
1⁄4 cup all-purpose flour
2 tablespoons Crisco oil or Olive oil
2 yellow onion, peeled and cut into large chunks
6 carrots, cut diagonally into chunks
3 stalks celery, cut into large chunks
4 cups water
2 bay leafs
1 envelope Lipton® Recipe Secrets ® BEEFY ONION
1 envelope Lipton® Recipe Secrets ® ONION MUSHROOM
2-4 dashes Kitchen Bouquet, for browning gravy opt.
Directions:
Season roast with garlic salt and pepper on all sides
Put flour into a bag and add roast, coat all sides of the roast.
In a fry pan, heat the oil on medium heat and add roast and brown on all sides. Once browned, remove from pan and blot excess oil off meat.
Place the pressure cooker trivet into pressure cooker and place roast onto to the trivet.
Add carrots, celery, bay leafs, and soup mixes. Pour water, enough to completely cover the meat
Close lid securely; bring to high pressure over high heat. Once the regulator starts to rattle, reduce heat to medium or level needed to maintain high pressure; cook for 1 hour.
After the hour is up, turn heat off and have pressure cooker release pressure naturally. Don't use quick release!!!!
* To make the gravy, remove roast and vegetables, cover with foil to keep warm. Strain the liquids into a saucepan, reserving 1 cup of meat juices for gravy. In saucepan, over medium heat bring meat juices a boil.
Meanwhile, in a small bowl, add 2 tablespoons flour to ¼ cup COLD water, whisking together to remove lumps. Then return flour mixture to pan; cook 2 minutes or until slightly thick, stirring constantly with a whisk.
* To make noodles, in a large saucepan, add butter and remaining meat juices. When the meat juices come to a boil, add 2 tablespoons parsley and 3 cups dry egg noodles. There won’t be enough meat juices to cover noodles and that's ok, because you want the noodles to absorb most of the meat juices. Cover and cook until the noodles are al dente, stirring occasionally so noodles on top won’t dry out.
Step 1: TIPS TO CREATE FASTER, HEALTHIER, TASTIER MEALS WITH PRESSURE COOKING, SAFELY!!!!!
For all of you that heard horror stories about pressure cookers, I'm so sorry! Let me just say . the pressure cooker doesn't have a brain or mind to think or act on its own... It's what you do OR don't do will determine the success or failure in cooking with a pressure cooker; To the point, only YOU have the control over the pressure cooker. The convenience, ease, and (yes!) safety of the modern pressure cooker will put your dinner on the table fast—and make it tastier, as if you spent the whole day at the stove.
Here are some safe guidelines to help ease your minds:
* Keep the rubber gasket clean and in good shape.
The gasket is the ring of rubber that lines the lid of the pressure cooker. If the gasket looks cracked or broken, replace it immediately. You might need to order the gasket online if you can't find it locally. Use parts that come from the pressure cooker’s manufacturer to ensure the proper seal.
* Follow the instruction manual.
Read the instructions several times before diving into a recipe.
* Measure liquids precisely.
This is critical to increase the cooker’s pressure. Follow a recipe to make sure the amount of liquid is correct.
* Don't overfill the pressure cooker.
Careful measuring is a must. Some foods, such as beans, expand when they cook, and you need to allow room for this.
* Be careful with frothy foods.
Frothy foods can block the steam valves and the pressure-release vents on your pressure cooker. Foods that froth include pasta, rhubarb, split peas, oatmeal, applesauce and cranberries. When cooking these foods, follow a trusted recipe and make sure the quantity in the pot is well below the recommended maximum-fill line.
* Release the pressure safely.
Typically, removing the pressure cooker from the stove and letting it cool until the pressure drops to the safe range release the pressure. The cold-water release is another way to release pressure by running cold water over the lid of the cooker. Each pressure cooker operates differently, so consult your instruction manual.
Pressure Cooker Benefits:
* Meats stay juicy and moist flavors are often intensified. Resulting in using less salt.
* 70% faster than conventional cooking techniques, resulting in less energy used.
* Perfect for those last meals without a lot of planning ahead. cooking saves you time cooking and heating up your home which is great during summer!!!
Wishing you a SAFE and Happy Cooking, Cyann :)
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    hope you'll give this recipe a try. If you do, be sure to leave myself a comment or two in the section at the bottom of this page and let me know ... Greatly Appreciated, Cyann : - )
