Introduction: Easy RGB LED
Picture of Easy RGB LED
Easy Red, Green, Blue LED arduino for beginners. I will include some different codes and what each means.
Needed
-RGB LED
-Arduino Uno
-Jumper Wires
-9v batt. and cord
Step 1:
Picture of
Step 2: RGB Pins
Picture of RGB Pins
Connect v pin to yellow wire, green wire to g pin, blue wire to b pin, and red wire to r pin. The color doesn't matter as long as you assign that color of wire to Red, Green, Blue, or ground.
Step 3: Arduino Pins
Picture of Arduino Pins
Connect the yellow wire to ground, then green wire to pin 13, blue to pin 12, and red to pin 11
Step 4: Code
Picture of Code
The code I have on it right now is just a simple blink sketch. It first turns flashes green for the setup, then in the loop flashes red and blue with a 200 delay. I will add more codes as I am able to make them.
Code:Blink
int green = 13; //declare/initialize led colors to their pins
int red = 12;
int blue = 11;
void setup() {
//initialize pins
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(200); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
digitalWrite(12, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(12, LOW); // turn the LED off by making the voltage LOW
digitalWrite(11, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(11, LOW); // turn the LED off by making the voltage LOW
delay(200); // wait for a second }
Code:Blink Without Delay
int red = 12;
int blue = 11;
void setup() {
//initialize pins
void loop() {
delay(1000);
delay(100); // wait for a second
delay(1000); // wait for a second
delay(10); // wait for a second
delay(50); // wait for a second
delay(20); // wait for a second
delay(1000);
delay(1000);
delay(2000);
delay(1000);
delay(1000);
delay(2000);
digitalWrite(11, LOW); }
Jaxton Maez (author)2015-01-19
You can change the order or timing by copying and pasting or changing the delay times.
int red = 12;
int blue = 11;
void setup() {
//initialize pins
void loop() {
djsadeepa (author)2015-01-10
void setup() {
// initialize digital pin 13 as an output.
void loop() {
Jaxton Maez (author)2015-01-09
I cant upload a sketch or video right now, but will as soon as I can.
About This Instructable
764views
16favorites
License:
More by Jaxton Maez:Arduino flashing LED lampEasy RGB LEDMini Pencil
Add instructable to:
