Introduction: Easy Red Laser (That Burns) for Under $40
Picture of Easy Red Laser (That Burns) for Under $40
Red lasers are sweet. You can go ahead and buy a laser but those can be expensive and not always be as effective. In this instructable I'll show you how to build your very own red burning laser for under $40. The process and Idea came from this video.http://www.youtube.com/watch?v=_VrNDe9mpOs
Step 1: Parts
Picture of Parts
Supplies:
1. Laser Diode- can be purchased for $20 on this site.
http://hightechdealz.com/product_info.php?cPath=21&products_id=36
2. Laser Drive- Can be purchased on this site for $13.
http://rkcstr.nfshost.com/index.php?main_page=product_info&cPath=65&products_id=201
3. 4 AA battery pack. Can be bought at Radio Shack for about $2.
http://www.radioshack.com/product/index.jsp?productId=2062253
4. Some type of insulation. I ruined my first one by letting it overheat.
Tools:
1. Safety Glasses
2. Soldering Iron
3. Solder
4. 4 AA batteries
Step 2: Soldering
Picture of Soldering
1. First find the positive and the negative ends of the diode and solder them to the front end of the driver.
Step 3: Step 2
Picture of Step 2
Next Soldier the two ends of the battery pack to the other ends of the driver.
Step 4: Step 3
Picture of Step 3
Now turn the screw on the driver all the way to the right. Make sure you don't overturn and break it. This will increase the power output.
Step 5: All Done
Picture of All Done
That's it. You can add some insulation so that it doesn't overheat. My first one burnt out because I left it on too long with no insulation. Now you can focus the beam and it will light matches, fireworks and make most black paper and rubber melt. Make sure you use appropriate glasses and safety precautions. just by looking at the reflection hurts your eyes and gives you a headache. Remember always be cautious.
Christianjjenkins (author)2013-06-20
Is there an on off button, how do you turn it on and off
Dimitrioptimus (author)2011-06-04
PLZZZZZ clarify my doubts
1>want to know that if I use Li-Ion batteries i.e; 18650 which are 3.7v 2600maH,then I have to use 3 of them connected in Series is that right(about 11.1 v )(since the total consumption will be about 7.2v),but these batteries comes with pcb protection so when I will be using this laser will the pcb should posses any problem.Secondly want to know that if this driver can handle 2600mah.
2>Then in case 14500 which is standard AA(1.5)then have to use 5 of them I guess,plz clarify if I am right or wrong.
3>Can u plz give the names of the chargers which charges these batteries,1 by 1 charging will not be a problem for me.
4>plz suggest the best lion battery manufacturers. I went to this site(http://www.candlepowerforums.com/vb/showthread.php?257543-LiIon-18650-battery-comparison)but cant decide which one to purchase.
Thankx in advance
instructables staff (author)2011-04-10
Hello,
We have been notified of copying others
please remove this from our website or we shall ban your account
from instructables.
Thank you
grover (author)2011-04-09
deifinitly stole it from kip kay
DiyProjects (author)2011-04-08
Where did you get this diagram?
the9n (author)2011-03-12
You can buy a burning laser, for just under $30. So why buy one?
sircowsox (author)the9n2011-03-16
1. this one is much more powerful than any laser I could find online. most lasers at this power cost about $200.
2. It's always fun to DIY.
iminthebathroom (author)2011-03-12
nice, when you say insulation, do you mean a heat sink? and if so is it mounted on the driver or the laser diode?
Any type of insulation. You could probably use electrical tape. I put the diode and driver into an old cheap laser pointer and it ended up heating up and burning the diode out.
thomas9666 (author)2011-03-10
Do the website in the links post to Britain?
jackh94 (author)thomas96662011-03-12
without wanting to sound like I'm advertising try odicforce:
These are links for a driver, diode and host for a blu-ray laser. If you make it it's mostly the same as in this 'ible but I can help you if you need as I've made one.
http://odicforce.com/shop/article_OFL122/Compact-Variable-Current-Boost-Laser-Diode-Driver-Board-for-Hand-held-Laser-0-300mA%2B.html?shop_param=cid%3D1%26aid%3DOFL122%26
http://s243333424.e-shop.info/shop/article_OFL107/PHR-803T--Blu-ray-Laser-Diode-405nm.html?shop_param=cid%3D14%26aid%3DOFL107%26
http://s243333424.e-shop.info/shop/article_OFL176/Focusing-Laser-Host.html?shop_param=cid%3D1%26aid%3DOFL176%26
schkip1973 (author)2011-03-10
yeah or burns out your eye.
temper (author)2011-03-09
What's up with those links? They all point back to this article.
sircowsox (author)temper2011-03-09
Sorry about that. you should be able to use the URL now I can't get the direct link to work so you'll have to copy and paste it.
temper (author)sircowsox2011-03-10
Cheers.
zazenergy (author)2011-03-09
That's pretty interesting!
About This Instructable
10,072views
77favorites
License:
More by sircowsox:Easy Red Laser (That Burns) For under $40
Add instructable to:
