Easy Ribbon Bow (2 Mins! No Sew!)
Introduction: Easy Ribbon Bow (2 Mins! No Sew!)
This is super easy to make bow using a ribbon and some PVA glue
You can make this in about 2 minutes flat!!
Dont believe me? Try it :)
Step 1: What You Need...
1. PVA glue
2. Scissors*
Material :Ribbon of your choice!
I have used Canada Fuchsia Satin Ribbon
*Note: Be careful using sharp instruments like scissors!
Step 2: Cut the Ribbon
Cut 2 pieces of 6 inches (15 cm)
and one piece of 2 inches (about 5 cm)
Step 3: Glue One End
Glue one end of the 6 inch piece using the PVA glue
Step 4: Make a Loop
Paste the ends to make a loop
Step 5: Pinch!
Apply glue to one of the inner sides of the loop and press the ribbon to form a 8-shaped loop
Step 6: Glue the Two 8s
Apply some glue at pinch of one of the 8.
Stick the other 8 at slight angle to it.
Step 7: Making the Cross
Apply a dot of PVA glue at the center of the ribbons and wrap the 3-inch piece around to form a loop.
Step 8: Cutting the Tails!
Cut two more pieces of ribbon of about 4 inch each.
Cut a small 'V' at one end.
Step 9: Pasting the Tails
On the rear side of the bow, paste the two tails made earlier
... and your bow is ready in 2 minutes flat!
Have fun!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
