loading
Step 5: Carve out blade section
Finally, you must carve out the area where the dado blade will fit in. This is where the position of the bolts is important. If the bolts are too close to the blade, they will need to be moved or the blade lowered.
Raise the blade to about half way up the fence, or about an inch, no more. If you think you will be making rabbets deeper than 1", make it higher, but not as high as to weaken the fence.
Trace the outline of the blade onto the fence. Now, you can either cut out the curve with a band saw or jig saw, which is much safer, or you can cut it out with the table saw which is not as safe.
To cut it out with the table saw, raise the blade so that the teeth are just on the bottom edge of the wood. You will slowly need to nudge the wooden fence over the blade to carve it out. Be careful not to go all the way to the metal fence as this will dull the blade quickly. Do this repeatedly until it is at the desired height.
And there you have it! You now have a perfect little cutout for the dado blades to sit so you can finely adjust the distance of them in the fence while having a straight fence to cut on.
nice job- I wonder if using a synthetic deck plank would be a good idea- less risk of warping. Of course then you probably would have to buy the material and not be able to scrounge it.
Pressed paper board is stable and at spots like Home Depot. It is stronger in most ways than you would ever suspect and weather will not effect it (indoors). They usually have one inch thick by about 30 inch lengths. A bit of Formica would stop surface wear from wood touching the board. And you could also laminate it to strand board or plywood for extra thickness and strength.
Yes, a synthetic plank would probably work, but I like to be green and use scrap.
If you don't want to drill the holes in your fence, you can add a wood fence using HoleClamps <br>http://www.grip-tite.com/GT1/HoleClamp.html<br><br>With those, you just drill a couple of vertical holes in the sub fence and clamp on.<br><br>
Oops; hit &quot;post comment&quot; too fast: also meant to say, great idea &amp; 'ible. I've favorited it.
Thanks. And dowel center points, never heard of them before. What a novel idea, it would come in handy often! Thanks for showing me them.
Dowel center points, or transfer plugs, would help in step 3: http://amzn.to/aT0vcV
About This Instructable
9,091views
14favorites
License:
More by Niemanator:TV Stand Coffee cup dispenser Easy Rip Fence Mod: Cut Easier Rabbet Joints
Add instructable to:
