Step 1: 1. Materials
MATERIALS
-Soda can (Doesn't matter what brand, as long as it's aluminum.)
-Optional: Aluminum tape (Not pictured)
TOOLS
-Dremel OR X-acto (or similar)
-Dremel cutting wheel attachment
-Vise
-Needle nose pliers
-Marker
Step 2: 2. Cut the Top Half
PICTURE 1
Choose a measurement to be used throughout your build. We used 3.5 cm. Draw a line around your can. This is the cut line.
PICTURE 2
Cut along this line as neatly as possible using your Dremel or knife.
PICTURE 3
Result.
PICTURE 4
Using a knife (a Dremel would be hard to use here), cut out the top of the can around the inside.
EDIT: According to SpinWard, you can also use a can-opener to cut it out (Which would be smoother). Thanks!
PICTURE 5
End result of entire step 2.
Step 3: 3. The Bottom Half
PICTURE 2
Demonstrating how to set up the blade by clamping the blade in the vise.
PICTURE 3
Cut around the line you drew by rotating the can around the blade.
PICTURE 4
Result of Picture 3.
PICTURE 5
Crimp the edge of the can by grabbing the edge of the can with your pliers and twist every 1/2 inch of so.
PICTURE 6
Result of entire step 3.
Step 4: 4. The Inner Wall
PICTURE 1
This is what you are making.
PICTURE 2
Measure the same distance from the edge as you did the other parts and cut, as shown in picture 3. We use 3.5 cm.
PICTURE 4
Cut picture 4 in a straight line any where on the ring.
PICTURE 5
Fit the ring around the inside edge of the top half and mark a spot where the two sides overlap on either side of the ring, as in picture 6.
PICTURE 7
Cut halfway up each place where you marked the overlap, and fit them together, like in picture 8.
PICTURE 9
Cut three holes on the ring about 120 degrees apart from each other. These allow the fuel to flow to the fuel jets.
PICTURE 10
Place the inner wall around the lip on the inside of the top half with the holes facing up.
Step 5: 5. Put it Together
CONGRATULATIONS! You now have a fully functional, lightweight backpacking stove! Proceed to the next step to find out how to use it.
Step 6: 6. How to Use Your Stove
EDIT: To make a wind shield/Pot stand, go to http://zenstoves.net/PotStands.htm.
![DSCN0142[1].JPG](/files/deriv/FTT/BMVA/GGAOZ5SC/FTTBMVAGGAOZ5SC.LARGE.jpg)
![DSCN0144[2].JPG](/files/deriv/FUX/JXWU/GGAOW3X1/FUXJXWUGGAOW3X1.LARGE.jpg)
![DSCN0150[1].JPG](/files/deriv/F62/8E3H/GGC2U38Q/F628E3HGGC2U38Q.LARGE.jpg)
Visit Our Store »
Go Pro Today »
Though you are right that the alcohol fire isn't large enough to be a problem.
tip: add house insulation (the pink stuff) inside the wall of the stove. it is inflammable and absorbs the alcohol.
In the parts list, I mentioned aluminum tape, which is some times used for HVAC systems. In your case, I would wrap the tape around the part where the two halves come together.
thanks for the guide.
Can you comment on the plastic lining in aluminum beverage cans for toxicity? And what about the paint on the outside?
I am assuming that the aluminum itself is not in direct contact with food so there is a smaller risk of inducing Alzheimers disease. :)
Nice design, I like it!
First lighting on left, after jets have ignited is the second photo.
If you want to see other fuels in thermal I will be able to when i return from Afghanistan and have access to them.
When i get more time I will make an instructable on mine, but I did use this as a guideline.
