Step 2Making the Cube - part the first
First pick 2 cards and set them on top of each other, and perpendicularly to each other. The top one should be roughly middle bottom one, then crease along the sides of the top card. Repeat until all twelve cards are creased in the same manner.
Now we're going to use 6 cards for the outer faces of the cube - which will both give it a stronger overall structure and make it look better while allowing us to tell what each Tikitag on the faces of the cube does. You can simply write what each face will do, or paste pictures on the faces, or print the corresponding icons. If you'd rather choose this option, you could use icons from SVG icons - they resize to any dimension using open source program freeware like Inkscape. Once this is done, you can either stick (or tape, if you want to reuse it for a later project) a Tikitag to the back of each of these 6 cards and move on to the next step.
EDIT : I took some time to make a second version of the cube, much closer to a model than to origami. Break out the glue, scissors and click along for part 1, 2 and 3.
Add Comment
![QR code augmented storage [Updated]](http://img.instructables.com/files/deriv/FEI/ZEEC/G7DY78EW/FEIZEECG7DY78EW.SQUARE.jpg)
