Step 3Remove Chip from Control Board
iImage Information
The next step is to locate the uln2003 chip on your stepper driver. If your board does not have one, you can order one online for about 50 cents. If your board has a uln2003, you must desolder the chip from the board. This step can be a bit tricky, but is not that hard. First, try to remove as much solder as you can using your desoldering pump. Once you have removed the solder, use gentle, prying force with the tip of a screwdriver. Carefully touch the tip of your iron to each pin, still applying force with your screwdriver.
ES MAS FACIL BUSCARLOS EN IMPRESORAS DE PUNTO, ESTAN CERCA DE DONDE ESTA EL CONECTOR DEL MOTOR PAP, SON 2 CHIP FACILES DE RECONOCER YA QUE ANBOS TIENEN LOS MISMOS NUMEROS EN LA CARA VISIBLE.
EN SCANNER NO HE BUSCADO PERO DEBERIA ESTAR CERCA DEL CONECTOR QUE VA HACIA EL MOTOR, PUEDES BUSCAR LA EQUIBALENCIA EN INTERNET, GOOGLE, ESCRIBES EL DATO DEL CHIP QUE SACASTE Y AÑADES DATASHEET Y TE MUESTRA LA PAGINA CON DATOS DEL CHIP. ESPERO QUE TE SIRVA
I recommend looking for the ones that have parallel or centronix ports on them. Possibly SCSI, too. The older ones were not small and you can easily see the "guts" and make you decision about its usefulness to you. Anything that has USB is probably going to have very little you want. They tend to have very small stepper motors and might be bi-polar. The exception being some of the UMAX Astra scanners that have parallel and USB. I also noticed the older ones tend to have really thick hardened steel rails. An added bonus for linear motion.
You can see a simple 1 axis version implemented like that here.
And thus the transistor that turns "on" first will take the full current load unless some sort of regulation is supplied to assure that each transistor in the array is "exactly the same"....
And to be truthful, I don't think there's any way to do that as the base leads to each transistor in the array are internal.
This circuit is good for 500ma per phase and there's a lot of small surplus nema 17 and nema 23 stepper that can be used with this circuit, but a lot that can't.
For those that can't, instead of using the ULN2003/ULN2803 just use a set of 4 TIP120's or TIP142's instead of the ULN chips.
look at these links for an idea of how this works and what your ratings will be:
http://www.luberth.com/plotter/TIP120schematic.png
http://www.luberth.com/plotter/tip120pcb.htm
