Step 8Conect and Test Motor
To test it, connect your 12 volt 300ma dc adapter into your barrel jack. Then, connect your DB25 port into your computer. Open the attached program in TurboCNC to test your motor wire connections. When you are done testing and changing your connection you should have a fully working axis.
To test the scale of your machine, attach a marker to your machine and run the test program. Measure the line. If yours is 1 inch long, or close to it, then your machine is good to go. If it is off, check your math. If you have made it this far, congratulations, the hardest part is done.
TEST.CNC18 bytes| « Previous Step | Download PDFView All Steps | Next Step » |
http://www.instructables.com/file/FZ0WAKRGT19NJTB/?size=ORIGINAL
From the page:
http://www.instructables.com/id/Parallel-Port-Break-Out-Board-BOB/step3/Whyd-You-Make-it-This-Way/
Which should have been in my image library but having looked through it a half of a dozen times I'm a bit tired of that now. So those links will have to suffice. Fire the webmaster! Or more fitting in this case, web disaster.
The riser cable is of course the flat gray ribbon cable plugged into the printer cable.
