Easy Toe Rings
1,932
76
Published
Introduction: Easy Toe Rings
This tutorial is for two different types of adjustable toe rings. They're so easy that you could just sit around & make them while you watch TV or, right before heading out in your open toe shoes.
Step 1: Materials
You'll need:
About 4" of craft wire
Jewelry pliers (needle nose hardware pliers work too)
A bead (optional)
Step 2: Type A- the Double Swirl
This is the easiest one
Step 3: Bend the Ends
Using the tip of the pliers, bend the end of the wire into a tight loop. One should face up and the other face down (see picture 2.)
Step 4: Make the Swirls
Bend each end a couple more times to create the swirl. Make sure one swirl points up and the other points down.
Step 5: Shape It
Wrap it around the pliers to shape it
Step 6: Type B: Toe Ring Bling
This one is a little more fly :)
Step 7: Put on a Bead
Just like last time, bend the end of the wire into a tight loop. But now, put on a bead and let it fall to the end with the loop (see picture 2)
Step 8: Swirl Around the Bead
Swirl the wire around the bead.
Step 9: The Other End
Swirl the other end of the wire like last time. Only now you're going to make it a bit smaller. Make sure one swirl points up and the other points down.
Step 10: Shape It
Wrap it around the pliers to shape it. Slide it off and you're done!
Step 11: Thanks!
Thanks for checking out my Instructable! If you tried it please share a pic :) Enjoy your toe rings!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
