Today I share with you my experience making a recipe from the Martha Stewart website. I offer the original recipe, and suggestions on how to make it even simpler and faster. I hope you have as much fun making these delightful little treats as I did. I can't wait to experiment with more daring flavor fusions. Hot peppers, here I come. . .
A small box or bag of truffles makes a great gift. With this recipe, you'll be able to whip out a batch in no time that your last-minute recipient will be convinced you spent hours on. No one needs to know!
Remove these ads by
Signing UpStep 1Supplies
- 1/2 cup plus 2 tablespoons heavy cream
- 1/8 teaspoon ground cardamom
- Five strips 1-inch-wide orange peel, pith removed
- 8 ounces semisweet chocolate, finely chopped
- 1/4 cup confectioners' sugar
- 1/4 cup sifted cocoa powder
- 1/2 cup finely chopped assorted nuts, such as walnuts, pecans, and pistachios
To simplify I suggest replacing orange rind with a splash of juice, if you have it around, and cardamom for your favorite seasoning that you also happen to have around. I found those to be the two ingredients that left me with stuff I had to figure out how to use up. (Yes, in the end, I just ate the orange. But I prefer Satsumas.) In the end though, I admit, the cardamom added a killer flavor, and I'm excited to find ways to use it up.
Also the heavy cream can be replaced with evaporated milk, giving you the ability to replace some of the fat as well!
If you go to hulu and look for a video from Alton Brown's good eats show it might be a little more informative then the Martha Stewart one was. Although his recipe takes more time he does break down how and why things are done plus has some really good tips to make the whole process go as smooth as possible. They could be easily incorporated in to yours if you see fit.
I get bored and make up various combos and let others come up with some too. The recipients have been more and more adventuresome as time goes by. My fav is german choc with carmel yummm
Two years ago I had a request for white choc, lime and halenpeno. I thought he was nuts but actually had 5 others that wanted it.
Last year the conf sugar (short cut) had higher than normal amount of corn starch and it ruined the texture - gave a thin coating - sorta like a pastille. So no white choc last year.
New neighbor plowed me out and loves white choc hopefully the conf sugar is good this year or I will be grinding from scratch
Ria
So you melted white chocolate with cream that was infused with lime + jalapeno?
I too have been having bad luck with 'off' batches of white chocolate. I'm switching back to Merkens brand.
I also cooked down the peppers and made it from scratch .. I did try a cheater batch using powdered chipolte - liked the flavor but it was harder to taste test for amount
I usually use Ghiredelli (sp) choc but have noticed that it is harder to melt evenly .. I seriously wonder if they changed their formula and are either using more wax or different type .. I found some from 3 yrs ago and it melts fine so think something else has changed
use a silicon spatula and work the white choc, I found if I pour off the well melted into a double boiler then work the stuff that doesn't want to melt right
I picked up new conf sugar will check it later for consistency
Ria
One of my fave recipes for cream cheese frosting uses a few ounces of dark chocolate melted with 3T of strong, brewed coffee. Once melted and whisked, it then is mixed into the cream cheese/butter/sugar part.
What you're essentially making with the cream/chocolate is ganache. Different ratios produce different "softnesses" of the original chocolate.
You can make white/milk versions of the filling by only using the cream (spice/rind ok) and no watery liquids.
One tip is to have the cream boiling, and then pour over the chips, or coarsely-chopped chocolate, then cover with a plate and rest for 10 minutes. Then when you whisk it together, it forms very well into that chocolatey goodness.
I will label it Scooch's Scoop in every I'ble I use it for, in honor of you!
Here is a "recipe" (proportions only) for a combination of dry, finely ground spices. The units are carefully unlabeled. I use 1/8 teaspoon measures. You can use any amount from "pinch" to "pound" and store your mix. I then use a "big pinch" of this mix in a single cup of tea to make my own Chai.
8 cardamom
8 cinnamon
6 ginger
3 black pepper
2 cloves
1 nutmeg
1 chinese 5 spice
1/2 allspice
1/2 mace
1/2 white pepper
I tried out your recipe, mashed up with Alton Brown's. Good stuff. I was very popular on valentine's day :)
I used champagne and frozen mixed berries, orange & clove (because I hate cardamom), and mint.
All turned out beautifully.
Thanks for the inspiration
I'm glad it came out well ;)
I finally found a tip on the net, to just keep a bowl of cold water next to you, and always dip your hand in it before rolling the chocolate....this keep the chocolate from sticking to your hands and makes the truffles really nice and smooth :))
Now, about yours not being as easy to roll as you thought - perhaps the freezer was a bit too much? Or you just left them a little too long? I'd suggest you take them out a couple of minutes earlier and/or leave them to warm back up for a couple...
Finally, does anyone know if 'heavy cream' is what we Brits call 'double' (or 'whipping') cream? - if not, then what? Thanks.
cream
n. Upon standing, unhomogenized milk naturally separates into two layers — a MILK FAT-rich cream on top and almost fat-free (or skimmed) milk on the bottom. Commercially, the cream is separated from the milk by centrifugal force. Almost all cream that reaches the market today has been pasteurized. There are many varieties of cream, all categorized according to the amount of milk fat in the mixture. Light cream, also called coffee or table cream, can contain anywhere from 18 to 30 percent fat, but commonly contains 20 percent. Light whipping cream, the form most commonly available, contains 30 to 36 percent milk fat and sometimes stabilizers and emulsifiers. Heavy cream, also called heavy whipping cream, is whipping cream with a milk fat content of between 36 and 40 percent. It's usually only available in specialty or gourmet markets. Whipping cream will double in volume when whipped. Half-and-half is a mixture of equal parts milk and cream, and is 10 to 12 percent milk fat. Neither half-and-half nor light cream can be whipped.
The site gives a copyright nod to Barron's Educational Services, Inc. 1995 based on THE FOOD LOVER'S COMPANION, 2nd edition, by Sharon Tyler Herbst.
Read More http://www.epicurious.com/tools/fooddictionary/entry?id=2121#ixzz0fKanhfpD
So, it seems I need to look for as high a fat content as I can, rather than being blinkered by our different terminologies...
Thanks again!
Basically double-cream sounds about right, since I'm assuming "regular" (or single?) cream might be what we call "light cream" here. If you whip heavy cream long enough, you'll get butter, but if you whip light cream, you'll get butter in watery clumps. Or at least I did. :^o
