3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Truffles
Step 8Rollin' rollin' rollin'. . .
Rollin\
Now is the moment of glory you've been waiting for.
Remove the pan from the freezer when the chocolate is firm but malleable.  Use a spoon to scrape chocolate into a ball, about 1" is good, but I won't judge you if you like them bigger.  It's a lot of chocolate to take in all at once though, so use your best judgment.
I had to coax my spoonfuls of chocolate into little balls.  They did not magically form for me like Martha tacitly promised.  After a little hand rolling (unless you can make the magic happen - and if you do, I want pictures!), place them in another dish or on a cookie sheet and send them to the fridge for a bit before dressing.
After about ten minutes in the fridge (plenty of time to finish preparing those toppings if you didn't before), it's time to dress them!  Roll them in the toppings to cover them, and place them back on the cookie sheet or dish, grouped by topping.  I say this, because I did not do that, and most of my truffles became hybrids of their original intentions.  But cocoa/powdered sugar was still good.
People didn't like the green ones like I thought they would.  I should have told them it was pistachio first, and maybe they wouldn't have been so put off by the color.
As I suspected, the powdered sugar ones took the day.
What will your most popular topping be?
19 comments
Dec 20, 2011. 6:54 AMtigerbomb8 says:
these are nice with honeycomb
Dec 15, 2009. 1:26 PMbatgerl says:
I use this SCOOP to make my truffle balls more "magically" round! :)
Dec 15, 2009. 4:19 PMFoaly7 says:
Hehe. A little Alliteration there. Scooch needz a Scoop.
Dec 17, 2009. 5:01 PMFoaly7 says:
That -----Is----- Awesome-----. :]
May 4, 2010. 5:10 PMrustyjack says:
 OH wow i have 1 already. Sweet
Feb 14, 2010. 4:19 AMbetaj says:
 I found it sooooo hard to make the truffles into balls.  I tried rolling them in my hands but the chocolate was far too sticky.
I finally found a tip on the net, to just keep a bowl of cold water next to you, and always dip your hand in it before rolling the chocolate....this keep the chocolate from sticking to your hands and makes the truffles really nice and smooth :))
Feb 14, 2010. 1:58 AMadapt says:
 i was going to make mexican hot chocolate truffles (chili powder, cinnamon and a tiny bit of cayenne), but then wussed out at the last minute! drat!
Feb 11, 2010. 7:20 AMkarlpinturr says:
Them Truffles sure look good, Scooch! My Dad likes Rum Truffles, so I might see if I can get some flavouring (he's petrified about drink-driving, so won't touch them if he thinks there's ANY alcohol) ready for Father's Day - whenever that is this year.
Now, about yours not being as easy to roll as you thought - perhaps the freezer was a bit too much? Or you just left them a little too long? I'd suggest you take them out a couple of minutes earlier and/or leave them to warm back up for a couple...
Finally, does anyone know if 'heavy cream' is what we Brits call 'double' (or 'whipping') cream? - if not, then what? Thanks.
Feb 11, 2010. 6:29 PMduck_tape_ says:
I'm pretty sure double cream is heavier than heavy cream.
Feb 12, 2010. 6:18 AMkarlpinturr says:
Thanks all! - I've done a bit of trawling, and found the following on epicurious.com:
cream
n.  Upon standing, unhomogenized milk naturally separates into two layers — a MILK FAT-rich cream on top and almost fat-free (or skimmed) milk on the bottom. Commercially, the cream is separated from the milk by centrifugal force. Almost all cream that reaches the market today has been pasteurized. There are many varieties of cream, all categorized according to the amount of milk fat in the mixture. Light cream, also called coffee or table cream, can contain anywhere from 18 to 30 percent fat, but commonly contains 20 percent. Light whipping cream, the form most commonly available, contains 30 to 36 percent milk fat and sometimes stabilizers and emulsifiers. Heavy cream, also called heavy whipping cream, is whipping cream with a milk fat content of between 36 and 40 percent. It's usually only available in specialty or gourmet markets. Whipping cream will double in volume when whipped. Half-and-half is a mixture of equal parts milk and cream, and is 10 to 12 percent milk fat. Neither half-and-half nor light cream can be whipped.
The site gives a copyright nod to Barron's Educational Services, Inc. 1995 based on THE FOOD LOVER'S COMPANION, 2nd edition, by Sharon Tyler Herbst.
Read More http://www.epicurious.com/tools/fooddictionary/entry?id=2121#ixzz0fKanhfpD
 So, it seems I need to look for as high a fat content as I can, rather than being blinkered by our different terminologies...
Thanks again!
Feb 11, 2010. 3:40 PMmr_eand1der says:
Over here in the 'States, whipping cream and heavy cream are basically the same thing, but things can get quite confusing since mainstream dairies will sometimes add things like carrageenan, polysorbate-80, di-glicerides and tri-glicerides to both-- all of which are thickeners that (they think) make it easier to whip cream.
Basically double-cream sounds about right, since I'm assuming "regular" (or single?) cream might be what we call "light cream" here.  If you whip heavy cream long enough, you'll get butter, but if you whip light cream, you'll get butter in watery clumps.  Or at least I did.  :^o
Feb 11, 2010. 8:46 AMMrFhrog says:
i'm not british nor have i ever been there, but in Canada, whipping cream and heavy cream are interchangable, not to much of a difference, generally if you want whipped cream you would buy the whipping variety, i think it's has some sugar and stuff added to give it some sweetness. so i would imagine that double might be the same as heavy.  Your best bet would be to try the double cream if it doesn't work, you'll still have a nice gooy snack to eat!
Feb 11, 2010. 9:54 AMkarlpinturr says:
Thanks for that - I'll give it a go, and let folks know (sorry - I'm a poet, though you might not know it!). As you say, a nice gooey snack would be better than no truffles!
May 12, 2011. 2:52 AMSupernewby says:
I wish I could edit replies.
There's a nice chart on this page: http://en.wikipedia.org/wiki/Double_cream
May 12, 2011. 3:50 AMkarlpinturr says:
Thanks - I'll favourite that - it'll help a lot.
May 12, 2011. 2:50 AMSupernewby says:
British 'Double Cream' will work in place of US 'Whipping/Heavy' cream. You are right in that you want a high fat content, at least 30%.
I've used Double Cream to make ganache, which uses the same basic method of the truffles (but less cream to chocolate ratio).
Dec 30, 2009. 1:40 AMLeeranW says:
Thank you for posting up this recipe. Just about everyone in the house loves truffles, but I've always found making them to be a bit daunting. Hopefully with this, we'll be enjoying one of our favorite treats a little more often! (I also might try using your thin mint coating recipe on these for an added luxury)
Jan 1, 2010. 7:53 AMLeeranW says:
I decided to do these as a new years treat for the party I was invited to.
With the first bite, my sweet tooth went into critical mass with the powdered sugar ones, I rolled a few in 100% Cacao though, that has an initial kick of completely unsweetened chocolate, which is then offset by the semisweet.
I'm planning on doing these again soonish, but based off the house commentary, I think we'll be substituting the semisweet with dark chocolate.
It is like you said though, these are very easy to make, and when they're given a coating of powder/nuts, they're an attractive treat. Thank you again for posting the Instructables!
Dec 23, 2009. 8:17 PMJuananz says:
This is a great recipe!
Dec 19, 2009. 10:12 PMjhoughtaling says:
A friend makes truffles in the easiest way I've seen. He lines a shallow pan with parchment paper, then scoops the hot chocolate mixture (ganache) into it and smooths it out. It goes into the freezer to solidify. Then, instead of rolling the solidified ganache into balls, he cuts it into squares. The parchment lets him get the square truffles out of the pan.
Easy-peasy.
Dec 19, 2009. 8:00 PMjustjimAZ says:
I used cocoa, powdered sugar, Ovaltine malt, and pistachio coatings.
My wife and I liked the pistachio best.  The kids loved the Ovaltine.  Really!
Using a mini melon baller I got 15 truffles, but I'm pretty sure I could have gotten 16 if I had made them all the same size.
Dec 19, 2009. 4:57 PMlimpport says:
 With this step, I would keep some cold water and a towel handy.  You don't want to handle the truffles too long with warm hands, or they start to melt.  But you don't want your hands wet while you handle them either, so make sure you dry them completely!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
3802
Author:scoochmaroo(Click here for more!)
Editor of the Food and Living channels, I believe making things is fundamental to being human! Follow me to see what makes me human.
