Now for what you'll need:
- The water you want to purify (duh!)
- A 20 oz soda bottle
- Soap and sponge (sponge is optional)
- Clean towel
- A fire source and a pan
- Scissors or exacto knife
- A rubber band (big enough to fit around the bottle)
I will add captions to the pictures to make them more understandable! :D
Note: the water will taste amazing once it's purified, so make sure not to drink too much, and especially don't drink and drive!
Visit Our Store »
Go Pro Today »
I''m going to filter some tap water, boil it, then shake it.
Then taste it of cours. This tap water makes me run to the bathroom a lot. Yuck
So there is something wrong with it. Maybe this will help and save me money as I won't need to buy bottled water.
Thanks a lot! It took quite some time to perfect the grammar and spelling so it really means a lot!
As for your question, shaking it should also do the trick if you can't aerate it so that will definitely help! For the taste, i've tried adding some salt to the water as i'm boiling it and I found out that it really does help the water taste better! The salt overpowers the blank taste of the water and if you put it in while the water is boiling, the salt melts in the water so there isn't any loose pieces of salt floating in the water!
Hope this helps! Thanks again!
