Introduction: Easy Way to Test IR Module
Picture of Easy Way to Test IR Module
Hi guys today i will show you that How to Test IR Module Everyone Need to first Make sure that IR module is working Perfectly or Not before Soldering .
Components Required :
IR Module
BC547
Resitor 470 ohm,1k
9v Battery
LM7805 IC
Red Led + Buzzer
Two 10uf capacitors and One 100nf capacitor
Step 1: Circuit Diagram
Picture of Circuit Diagram
The circuit Diagram is very simple If it,s hard to find 9v Power supply so it,s ok you can Connect 12v Dc power Supply further it,s Duty of LM7805 to Regulate the Dc voltage to a 5V constant dc Voltage .
Step 2: It,s Working
Picture of It,s Working
***MUST DOWNLOAD THE VIDEO ***
When you Put your Hand in front of The IR module it will Make the O/p pin Low to 0v and you will not hear a Buzzer sound but when you Remove your Hand the Buzzer will start Sound because now IR module Output pin = 5v Now we can Receive 5v at the base of the BC547 transistor .
amberrayh (author)2015-04-13
This looks very simple. Thanks for sharing! I hope we see more from you on Instructables in the future!
About This Instructable
772views
18favorites
License:
Bio: Electronicslovers started in July 2011 with the mission to produce ideas to student and engineer or hobbyist to learn electronics practically. Electronicslovers provides information by ... More »
More by Electronicslovers:Learn How to Setup the Wifi Module ESP8266 by Using Just Arduino IDEMade a Radar Station by Using Arduino | Do It Yourself ProjectLearn How to Make Simple Obstacle Avoiding Robot at Home
Add instructable to:
