#1 Easy Soldering Table
1,208
59
Posted in WorkshopTools
Introduction: #1 Easy Soldering Table
An easy soldering table with 2 types solder stick supply and LED light.
Step 1: Clips
2 clips are welded to twist steel wire.
Step 2: Twist Wire Fixing
3 separated glass fiber plates between 2 10x10mm wood bar to fix the wires, glued with high adhesive glue.
Step 3: LED
A 5V USB LED is used for light.
LED is supported by 2 steel wire.
Powered by 3x1.5V battery.
Battery case with switch.
Step 4: Solder Sticks
I choose 1.0mm and 0.5mm solder sticks.
Step 5: Base
A hard disc shell is used as the base (you should choose something heavy as the base), so it is stable enough.
The wooden support and battery case are glue to the bottom side of the shell.
4 rubber pads are adhesive to the upper side of shell.
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    2 Comments
    Excellent Instructable !
    Nice, but better if you modify the title from welding to soldering. Ok?
