Easy Wire Wrapped Bead Link
1,111
48
Posted in CraftJewelry
Introduction: Easy Wire Wrapped Bead Link
About: I like to learn things, and make stuff. Buy my jewelry at www.MarcyBell.com and see what I'm working on at www.facebook.com/MarcyBellJewelry
This is a basic wrap, that you will use daily when you wire wrap. You can easily hook multiple beads together, to form a chain, or hook to anything with a hole. You can also add daisy spacer beads, or wrap multiple beads together into one link.
Step 1: Tools and Supplies
-chain nose pliers
-round nose pliers
-flush cutters
-bead(s)
-3-4" of wire that will fit through the hole in your bead. I mostly use 24g and 26g.
Step 2: Begin by Bending the Wire
Use the chain nose pliers to bend the wire as shown, about 1/3 of the way down the wire.
Step 3: Form a Loop
Grasp the wire with the round nose pliers, and form a loop that you center over the wire, as seen in the photo. The end of the wire that forms the loop is the working end of the wire. The other end I'll call the base wire.
Step 4: Hold the Loop With Pliers
Use the chain nose pliers to hold the loop.
Step 5: Wrap the Wire Once Around the Base of the Loop
Holding the loop in the pliers with your dominant hand, use the fingers of your non-dominant hand to pull the working end of the wire around the base wire firmly, one time. Check the photo to see what I mean.
Step 6: Slide the Bead On, and Bend the Wire to the Side
Slide the bead onto the base wire, and bend the wire slightly to one side, as shown.
Step 7: Form a Loop
Use the round nose pliers to form a loop that is centered over the bead hole. Reposition the round nose pliers on the loop, if necessary, so that you can center it properly.
Step 8: Wrap the End of the Wire Around the Base of the Loop
Use the chain nose pliers to hold the loop, and wrap the end of the wire around the base/neck of the loop, firmly, at least 2-3 times.
Step 9: Trim the Wire With Flush Cutters
Use flush cutters to trim the wire. I try to end the wrapping close to the loop, not close to the bead. Then I try to trim it so that I can use the tip of my chain nose pliers to crimp the end into the inside of the loop, ensuring that it won't poke someone.
The second photo shows where I've cut the tail of that wire.
Step 10: Turn the Bead Around, and Wrap the Other Side, As in Step 8
Turn the bead around, and wrap the other loop the same way that you did in step 8.
Step 11: A Better Pic of How to Position the Wire Before Cutting
A better pic of how I position the wire, before cutting it.
Step 12: Cut the Second Wire
Cut the second wire, just like the first.
Step 13: Crimp the End of the Wire
Shows the end sticking up, after cutting. You don't want to leave it like this, to catch on clothes, or poke people.
Use the chain nose pliers to crimp the end into the loop, as shown.
Step 14: The Finished Bead Link
The finished bead. Wire several of these together to form chain.
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    2 Comments
    that looks like a very strong link. Where did you buy your tools? Thanks.
    Various places. I looked around until I found the brand I wanted, for the best price. The blue handled pliers in this are Tronex, which I LOVE. They are the best cutters! The white handled pliers are Lindstrom. Thanks!
