Introduction: Easy Wooden Ornaments
UPDATE: if you like these but don't have access to make them yourself, you can buy them from me here
It is very easy to create beautiful, natural wooden ornaments. This method can be used to create these ornaments out of an assortment of materials, and using several different construction methods depending on what you have available to you:
Laser cutting is the simplest, but I'll go over the extra steps needed to use a CNC machine.
I used several types of 1/8" hardwoods to make these; specifically African Mahogany and Walnut.
- Laser cutting
- CNC milling
- Scroll / Band saw
- Hobby saw (by hand!)
Step 1: Create Your Star / Snowflake Design
I used this convenient Snowflake Generator I made to create this Chicago star design. You can also use it to create way more complex shapes though! Then you can simply download it as an SVG file.
Step 2: Create the Notch for Interlocking
Open the design in a vector editor such as Illustrator or the free alternative Inkscape which is available for all operating systems. Then you need to create a notch halfway into the design. The width of the notch has to be the width of the material you are using.
For my 1/8" wood, I made a 1/8" notch in the star that went down to the middle of the star. If you want the file I used specifically, you can get it here.
Step 3: [Milling Only] Generate Tool Paths
I use the web based MakerCAM to create the g-code toolpaths for my Shapeoko 2 CNC machine. It is very simple:
- Upload the SVG file by going toFile -> Open SVG File
- Click on the shape and go to CAM -> Profile Operation
- Input your bit size, material depth and feed rate settings, and click Ok
- Click CAM -> calculate all
- Click CAM -> export gcode
