3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy and Light Skate Box Setup
Hello!
This is a simple how-to for making a good quality skate box that can be portable. The decision to make your own box is really a natural one when all street spots are a bust and the parks are overcrowded. This particular box can also be made fairly cheaply especially if you have some plywood and 2x4's lying around. The only non-common components are the right-angle bar and masonite.
I have attached a small pdf with drawings of the box and dimensions.
Here's a short video of my friend skating the box:
http://www.youtube.com/watch?v=RW3-vSasAT0
skate_box.PDF(792x612) 498 KB
Step 1Considerations and Materials List
We had several restrictions in mind when designing the box:
1) The box had to be able to fit in the car. In our case unfortunately, this meant that the box had to fit into a Subaru STi. This gave us a max length of under 6'. Our final length was 66" and the box just fits in snug enough to shut the hatchback. This works fine for us but a longer length would be more comfortable to skate. I recommend going with something around 7' - 8' if you have a larger vehicle or are not concerned with moving the box. Keep in mind though that the length of the box will be limited by the length of right-angle bar that you can find. At Home Depot, the longest one I could find of decent stock was 6' length.
2) The box had to be sturdy enough to take a beating and get skated regularly without breaking down.
3) Light enough for a person to carry by hand.
Parts! The parts list is fairly short so here goes:
1) The all-important right angle bar! This is what you will actually be grinding and limits the maximum length that you box can be. As I mentioned earlier, the length of this bar will limit the maximum length of your box and at Home Depot I could only find 6' length. You should be able to find longer ones elsewhere. NOTE: make sure you are using steel or the densest metal you can find and it should be at least 1/8" thick.
2) Sheet of masonite: Try to find one that matches the thickness of your metal bar.
3) Sheet of plywood: get a sheet that is 3/4" or thicker.
4) There is not much to the 2x4's. It is important to look for the straightest pieces possible and make sure you get a little more than you think you will need.
5) Screws: we used standard 2" wood screws to fasten the top pieces (plywood, masonite, metal bar) and used 3" stainless wood screws to fasten the 2x4's to each other.
Home Depot Note: they offer a cutting service that should definitely be taken advantage of for the plywood and masonite pieces if you buy them there. I do not recommend cutting the 2x4 pieces to size there. You should be measuring each fitting as you go and then cutting the 2x4's to the correct size (there is usually some play in the actual lengths).
30 comments
Oct 26, 2011. 5:05 PMTechnolio says:
Hey Man awesome setup, I was thinkin about makin somthing like this out of pallets (of course using a solid sheet on top) just using pallets for the frame, and i like the idea for the Masonite.
very good product bro, this has definitely inspired me.
Jul 20, 2011. 8:46 AMezabala1 says:
how tall is it?
Jan 26, 2011. 2:42 PMLaTer says:
Do I need to use the Masonite? I know it levels the iron with the wood, but is it necessary?
Jan 28, 2011. 11:41 PMLaTer says:
Thanks, do you think you could link me to some of that hardboard at lowes/home depot? The closes I saw was: http://tinyurl.com/6cbz2r4
Would that work?
Oct 10, 2010. 5:38 PMsk8rforlife says:
Where did you drill the holes for the metal bar?
Jul 28, 2010. 9:21 AMmetal-child says:
i love building stuff to skate. where i live we have no park within an hours drive so me and my friends are always building boxes and rails. i have a miniramp above my garage and my mom is trying to get a park built. keep these coming im running out of ideas lol
Mar 19, 2010. 6:25 AMRebelSk8erD says:
hey bro... I just finished my box =DD i'll be bringin it home tonight but... i just snaped my board a few days ago lol.  so, once i get a new board (probz this weekend) i'll send ya some pics haha
once again, awsoem instuctable... a few of my friends are thinking about makin' one to now =D
May 10, 2010. 8:59 AMRebelSk8erD says:
You should do a half-pipe or something :0  Once I get some $ saved up I'm thinkin bout makin1 cuz It costs wayyy 2 much 2 buy 1 :/
May 5, 2010. 5:28 PMMarker1024 says:
 Great product i made one out of an old desk in my basement. Thanks dude you really inspired me to skate curbs and build stuff to skate.
Apr 1, 2010. 2:01 PMRebelSk8erD says:
hey bro uhh... i finished my box a bit ago and I just got a new board so I started sk8ing it 2 day but... one of my ollies were crap and well, I cliped the edge with my back truck... my point is, it left a decent ding in the side of the masonite... do u know how i can stop that or treat it or w/e?? thx :))
Feb 4, 2010. 12:17 PMRebelSk8erD says:
Hey bro... awsome box.  I'm planning on building this for a tech-ed project.  However, i just have a few questions...
1. About how much do you think the "angle bar" will cost?
2. Is the "masonite" important? or could i just use some good quality wood with some good stain or somethin'?
thx for the help bro =))
Feb 4, 2010. 3:10 PMRebelSk8erD says:
awsome man thx... will do
Feb 4, 2010. 1:43 PMRebelSk8erD says:
oh and 1 more thing... i was at skewl when i first came across this... just wanted to say your friends a rad sk8er =D
Jan 17, 2010. 1:50 AMsharlston says:
how about a small ramp?
Dec 6, 2009. 11:11 PMwtfisalinh says:
 im gonna try to make this :D
but with 2 right angle bars on the sides
Dec 7, 2009. 6:40 PMwtfisalinh says:
and btw
how much did this all cost u?
Sep 23, 2009. 2:01 AMeschompthis4star says:
hey good funbox, ive made many, heavy ones light ones very heavy ones, since we would take ours to our local school what a pain they were after a session having to drag it in home, nice skating btw
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:nonoodlez(Find, Fix, Design, Make)
