Easy and Light Skate Box Setup by nonoodlez
Featured
Step 2: Assembly Part 1
I should have taken pictures while putting this thing together but since I didn't I decided to put together some Solidworks animations depicting each step.
This first step is simple and just uses the sheet of plywood cut at 66" x 24", two pieces of 2x4 cut at 66" and the other two pieces cut at 21". Using the plywood sheet as a baseboard make sure to screw in everything securely to the plywood first and then put in screws attaching the 2x4's to each other.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
